CLS Coupe (C219) Discuss the CLS Coupe.
Dealer replaced the Valve Body...now what?
Old Nov 21, 2013 | 05:24 PM
Jr425's Avatar
Cls550
I'm hoping someone can chime in on this ongoing issue.
I have taken the car to the dealer for the infamous jerky transmission issue. Twice the shift adaptions were done, and recently the valve body was replaced. Still, the downshift jerk continues. Has anyone encounter a similar problem after the valve body swap? The dealer seems stumped at this point...
Car current sitting at 51k and had the ATF changed at 39k by Mercedes.
Old Nov 22, 2013 | 01:14 AM
skeppa's Avatar
CLS 500
Have you asked them to flash the tcu?
Request dealer flash engine control module then flash transmission control module if newer software is available. Modules may need to be SCN coded affected shifts may require re-adaptation afterward – reference DTB P-B-27.00/108.
Old Nov 23, 2013 | 09:46 AM
Jr425's Avatar
Cls550
Thanks Skeppa,
Well I'm assuming that every time they reset adaptions it's the tcu?
I will mention resetting the ecu beforehand this time.
Hopefully that would do it.
Old Nov 23, 2013 | 04:46 PM
skeppa's Avatar
CLS 500
Originally Posted by Jr425
Thanks Skeppa,
No, resetting adaptations is simply a reset of the ecu which you could do yourself by searching "ecu/tcu reset" which will reset the vehicle's stored driving adaptations. You'll likely have to get the tcu flashed for an update, just ask them to check if there is an update. If it's the same problem I'm having, the bulletin for it was "LI27.00-P-045854: HARD COASTING 2-1 DOWNSHIFT OR SLOW START(2009-01-28)". My only issue is when coasting under 20km/hr, the last two gear shifts cause jerking. I'll be getting it checked it out next month as the dealer is booked far into december .
