CLS Coupe (C219) Discuss the CLS Coupe.
Wheel Offset Question
Old Mar 11, 2014 | 01:29 PM
AvocentAMG's Avatar
CLS550
Does anyone know if this rear spec will fit?
20" x 10" +42 with 275/30/20
I'd imagine I need a 10mm spacer but will it work without the spacer? Or will it push in too much? Not a big fan of spacers.
The fronts are 20" x 8.5" +25 245/35/20 which im sure are fine.
Old Mar 11, 2014 | 07:15 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Fronts are fine.
Rears MAY rub under certain conditions (turning or while in sport suspension mode).
I just did this exact scenario and I rubbed; barely, but I rubbed. I put in 10mm spacers and its all good.
Old Mar 12, 2014 | 07:13 AM
AvocentAMG's Avatar
CLS550
Originally Posted by unlukky
Fronts are fine.
I was hoping to not go the spacer route. I've always had bad luck with them in the past.
Thanks for the reply! I think I'll pass on these rims.
BTW looks like you're looking for a decently priced lowering module. Have you researched ProgRama?
I have the Renntech V2 w/ remote in my car right now and it's basically a ProgRama module, just rebranded.
Old Mar 12, 2014 | 04:15 PM
unlukky's Avatar
I'll look into that. Thanks.
What kind or bad luck did you have? Vibration? Breakage?
Its the first time I have ever put spacers on any vehicle I've had.
John
Old Mar 13, 2014 | 07:36 AM
AvocentAMG's Avatar
CLS550
John
Mostly vibration at certain speeds (60km/h, 120km/h).
I had to take off the wheel and reseat the spacers. After that the vibration went away.
I like to have perfect fitment without any addons.
