Airmatic problems?
Airmatic problems?
Driver side rear was 3/4 in. lower than passenger side rear. Drove it that way for about two weeks while trying to read up and figure out what to do. No warning messages, but still disconcerting. After sitting for a week the rear corner dropped even more. I went ahead and replaced rear air strut. The ride seems fine but after turning the car off it is still sitting uneven, although only by 1/4 in. now. What else should I check out? Any suggestions would be greatly appreciated. Thank you.
The correct,repeat correct way would be to find someone who can scan the Airmatic control module---all else-- guesses, misinformation, a date bla bla!!
Yea I know, you will have to spend some money!!
aewiggins (08-18-2016)
Rear level link where does it go attached to
I see the end with the bolt not that side but the other side that looks like it goes attached to something like a pipe or something is that what it goes attached to or where exactly does it go
