CLS Coupe (C219) Discuss the CLS Coupe.
front window issue
Old Nov 30, 2017 | 03:47 PM
clster's Avatar
CLS350 CGI
front window issue
I have a 08 CLS. I used the front passenger window the other day (for the first time I think) and when tried to raise the window up again it stopped when it came to 60-70% and went down again, it did this twice when I just pulled and used the "automatic" window and then I had to pull and hold for the window do go all the way up and it sounded like if it was gravel inside the window mechanism. Is there any thing I can do as a man with limited experince?
Old Jan 3, 2018 | 04:48 PM
locomercedes's Avatar
2007 CLS550 Designo; 2009 Mini Cooper; 2011 BMW 335d
It happened to me. Bad window regulator in my case
Old Jan 7, 2018 | 12:02 PM
buzescu's Avatar
2008 CLS550, 2001 C240
100% your window regulator is gone.
I changed one recently. You will find that changing this is expensive... Best, if you think you can spare couple of hours and are handy buy it online, should be around 300-350 (sure you can find it more expensive but look around, dealerssell them cheaper). You will find instructions on the forum. At the shop .... expect 1000 at least.
