CLS Coupe (C219) Discuss the CLS Coupe.
Location of Secondary Air Injection Relay
Old Dec 27, 2017 | 06:40 PM
realog's Avatar
Hi there, could someone help me find the Location of Secondary Air Injection Relay. I have a 2006 CLS500 with no fuse/relay diagram. It would be even better if someone happens to have a copy of the relay/fuses diagram.
Old Dec 28, 2017 | 11:30 AM
konigstiger's Avatar
'71 Pinto
Front SAM (engine compartment) “R”.
Testing: https://www.pelicanparts.com/techart...ts_Testing.htm
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 28, 2017 | 09:33 PM
realog's Avatar
Thanks for the response. Today, I went to my local Mercedes dealer and the they sold me Hella Relay #002-542-72-19 but the Relay that was in the car was TYCO #002-542-13-19
I hope this is a direct replacement part? I swapped out the relays and everything seems to be working fine. I'm just left wondering if this is a direct replacement considering part numbers are different?
Old Dec 29, 2017 | 12:15 PM
'71 Pinto
Should be fine see cross references here: http://www.autohausaz.com/pn/0025421319
