CLS Coupe (C219) Discuss the CLS Coupe.
Keyless Entry Not working on Driverside?
Old Nov 2, 2018 | 03:16 PM
armaniE55's Avatar
2012 CLS63 AMG
Keyless Entry Not working on Driver-side? Does anyone know why this would happen and how to fix it? The passenger side works perfect which leaves me to believe it might be a fuse? This car is still pretty new to me.
Thoughts?
Thanks!
Armani
Old Nov 2, 2018 | 04:10 PM
konigstiger's Avatar
'71 Pinto
Need to replace door handle sensor inside is malfunctioning, part # 21176011709650
$188.78 https://www.parts.com/
$188.80 https://www.mbpartscenter.com/
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 2, 2018 | 04:21 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Really? wow ok. I thought for sure it was a fuse sense they both stopped working at the same time. Can you double check the part numbers for me. I have a 2007 I think the part numbers are for 2008. I appreciate the quick reply and part numbers! whoo hoo! I'll take on this project when shes sleeping for the winter. Wonder what what cause them both to malfunction.
QUOTE=konigstiger;7593332]
$188.80 https://www.mbpartscenter.com/[/QUOTE]
Old Nov 2, 2018 | 06:21 PM
'71 Pinto
Originally Posted by armaniE55
Keyless Entry Not working on Driver-side? The passenger side works perfect
I thought for sure it was a fuse sense they both stopped working at the same time. I have a 2007 I think the part numbers are for 2008.]
So which is it driver side only or both? If both sides then it is not the driver side handle have someone pull fault codes using MB DAS (diagnostics) for definitive answer. Is WDDDJ77XX7A094361 (07 CLS63) not your VIN https://mbworld.org/forums/market/725900 ?
Old Nov 5, 2018 | 12:50 PM
armaniE55's Avatar
2012 CLS63 AMG
Correct VIN thanks. When I pulled up the site to look at the parts I didn't see any listings with my year. Thanks for confirming.
To confirm it's only the driver side (front door and rear door) passenger side works perfect, which I think is odd for both of them to stop working. I'm thinking relay fuse or ?
Old Nov 5, 2018 | 03:03 PM
'71 Pinto
Replace handle as suggested.
Old Nov 5, 2018 | 03:49 PM
armaniE55's Avatar
2012 CLS63 AMG
Noted and Thank YOU!!
Armani
