CLS Coupe (C219) Discuss the CLS Coupe.
Did a fault scan on my car and I have tonnes of fault codes
Old Feb 25, 2019 | 03:04 AM
Thaya60's Avatar
cls 350 w219
I have bought it to 5 workshops and none of them could explain on why the same codes appear all the time.
Old Feb 26, 2019 | 03:41 AM
Thaya60's Avatar
cls 350 w219
Originally Posted by Plutoe
Clear all the faults---run another short test----- what faults return!
Tq brother I cleared the faults and did a short run again all these codes popped up again, these codes can be seen thru the diagnostics but when in run no pop ups appear in the instrument cluster .
Old Feb 26, 2019 | 04:11 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
That's a lot of faults! You got your work cut out for ya. Can't believe a dealership couldn't figure out why.
Old Feb 26, 2019 | 06:30 AM
Thaya60's Avatar
cls 350 w219
Could the communication gateway throw these codes if it's faulty?
Old Mar 24, 2019 | 08:43 PM
Exorpmtech's Avatar
C230
Typical MB with faults in a lot of the modules. What issue are you chasing?
Old Mar 25, 2019 | 01:00 PM
LexBrett2's Avatar
2007 Mercedes E550
I believe those are just intermittent open circuits. As long as you don't have a check engine light with normal OBD2 emission codes, and your car runs fun, just ignore those and be happy. Otherwise risk going down a endless rabbit hole.
Old Mar 26, 2019 | 08:53 PM
Thaya60's Avatar
cls 350 w219
I see so I should ignore. Is it possible different scanners can read codes that are actually not current codes or just stored codes? Tq very much for the advices.
Old Apr 19, 2019 | 07:56 AM
Thaya60's Avatar
cls 350 w219
I have replaced the central gateway with a brand new unit and majority of those codes are no longer presenting . I believe the air cond was sweating leaking to the central unit, when I opened up the unit I saw corrosion.
Old Mar 6, 2020 | 02:00 AM
Geminiman's Avatar
W222 - S550
clear all the DTC and run the car on the road for 10 miles and check again. Vedis II is not the best tool to work on Mercedes, get a Xentry.
