Rear side is low
Rear side is low
This is a new to me 2015 CLS, 45K miles. The right rear suspension is low. There are no suspension warnings.
I really want to fix this and have been told of bag replacement that may or may not fix it and have read some threads about sensors, etc.
Can someone help me on how best to approach fixing this issue without spinning my wheels.
Thank you
Thank you
Im going through this right now. My driver side rear is about 1" lower than my rear passenger side.
The only thing im finding here is "check for leaks"
Also i found out the rear has only 1 rear sensor for both wheels. That seems weird to me.
I am going to check the connections. "spray them with soapy water". You will need to do the same. There is also a "self leveling" valve in the trunk that ill be spraying down also.
