CLS Coupe (C219) Discuss the CLS Coupe.
Headlight autoleveling module location
Old Feb 7, 2020 | 05:56 AM
aalmans's Avatar
Mercedes CLS W219
Hi,
The autoleveling on my CLS has stopped working on both sides and after reading this forum this may be caused by a defective autoleveling sensor. I have just not been able to find the location of this module.
Could someone point me in the right direction please? There are a number of replacement modules i can buy but wanted to check first if it is the right type
Thanks!
Old Feb 7, 2020 | 08:33 AM
konigstiger's Avatar
'71 Pinto
VIN?
Old Feb 7, 2020 | 04:13 PM
aalmans's Avatar
Mercedes CLS W219
WDB2193561A043915 should be it?
W219 CLS from 2005
Old Feb 8, 2020 | 10:01 AM
'71 Pinto
Best I could do, EPC diagram. Consider checking axle sensors first, easily damaged.
Old Feb 8, 2020 | 04:59 PM
aalmans's Avatar
Mercedes CLS W219
Thanks, really appreciated. Will have a look tomorrow. Would you think the level sensor is indeed at fault here as both headlights are pointing downwards?
Old Feb 8, 2020 | 05:26 PM
'71 Pinto
Pulling codes should detect malfunctioning CU, level sensors, and range adjustment modules @ each headlamp. Steadfast on not pulling codes and replacing parts begin with level sensor inspections, move on to CU. Odd that both headlamp modules, and internal motors and/or more than one level sensor will malfunction simultaneously but warrants inspection. In addition, if you have not already done so, check f52 @ front SAM (engine compartment) for CU, f66 for headlamps.
Old Feb 14, 2020 | 05:45 AM
aalmans's Avatar
Mercedes CLS W219
Thanks!
I checked the fuses and they are ok. No error codes with MAxiECU program i have. Have tried to find the CU under the passenger seat but cannot seem to locate it. FRom the diagram it should be there right?
Old Feb 18, 2020 | 01:48 PM
'71 Pinto
File Type: pdf
Old Feb 18, 2020 | 02:08 PM
aalmans's Avatar
Mercedes CLS W219
Thanks!
Wow, looks like a project on its own to replace that control unit if i have to take the seat out! And it needs a STAR recalibration? Hmmm, i'd better go to an indy to have this checked i guess...
