CLS Coupe (C219) Discuss the CLS Coupe.
Cls500 new owner small issue
Old Aug 4, 2021 | 08:59 AM
m.amza91's Avatar
Mercedes CLS500
Hello,
Since yesterday I am a proud 2005 cls500 owner. I have a small issue I am not sure if this is the correct place to ask the question if it isn't I apologise. The driver side door mirror does not move when I press the door button. Could be the fuse, the wiring or the motor. My question is there a separate fuse for this mirror and if it is where is it located? I would like to check the fuse first. Thanks.
Old Aug 4, 2021 | 12:04 PM
konigstiger's Avatar
'71 Pinto
No dedicated fuse function originates from door control module. Remove cover 11 (see doc 1000tx) check wiring. Fine, disassemble mirror to check harness, motor etc.Fine, check door control module wiring. And last, although not common, could be mirror switch.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
