CLS Coupe (C219) Discuss the CLS Coupe.
Replacing Windshield Cowl Seal Covering / Cowl Grill
Old Oct 24, 2021 | 02:37 AM
benbac's Avatar
'06 CLS 500
Hey guys, I need to replace the windshield cowl seal covering or cowl grill (not sure if that's even the name), this is the part i'm referring to, as you can see mine is rotting away
I was wondering if anyone has been able to successfully do this themselves and can share part#'s, instructions, and/or tips (is it just one part or do i need several parts).
Cowl seal covering / cowl grill
Old Oct 25, 2021 | 08:47 AM
benbac's Avatar
'06 CLS 500
Thanks Plutoe, that epc was helpful, it seems it may be part of the WATER BAFFLE WITH INTAKE SHELL, HEATING AND VENTILATION and referenced as COVER ABOVE WIPE SYSTEM "A 219 830 00 13" which correlates with my assumption that it is referenced as Cowl Grille - Mercedes-Benz (219-830-00-13) on the MB parts catalog. However, I'm looking for some help confirming the actual part #s, if "219 830 00 13" is the part needed, and if there is any other parts are needed as well in addition to instructions and tips to replace it.
e.g. if the Cowl Grille is the part, do i need the other parts around it in order to replace it
2198300013 - Body: Cowl Grille
2119880081 - Body: Cowl Grille Fastener
1239900592 - Body: Cowl Grille Rivet
0029925501 - Body: Cowl Grille Grommet
2199870066 - Body: Cowl Grille Seal
Old Oct 25, 2021 | 09:52 AM
konigstiger's Avatar
'71 Pinto
If purchased new all inclusive with the exception of attachment rivets. Check your email.
