Chasing a suspension gremlin
Strange. I couldn’t replicate the grease trick as my Arnott strut didn’t seem to be the same. Not sure what to think but I sent it back and they replaced. It had been perfect since on driver side and passenger side was replaced a year ago and it has been good.
I did the grease trick to my original Arnotts and it quieted them down. However they still sound like crap over bumps. I'm at a loss for chasing this noise in the suspension. My next option is to spend $2000 on Bilstein struts to see if it fixes the issue..🙄
After months of being annoyed with a weird suspension noise and replacing basically the entire front suspension except for the sway bars and upper control arms.I replaced struts, lower front and rear control arms, every ball joint, sway bars endlinks, steering rack bushings,inner and outer tie rods and new Bilstein struts. Thank God I do all my own labor and the parts aren't terrible expensive except the struts, which I needed anyway.
I finally think I found the culprit of my noise...It seems like it's either the actual rack, the column or most likely the steering coupler. I just ordered the coupler since it's the cheapest part and it feels like there is play in it. The one weird thing is once the car is running and the rack is pressurized I don't hear it from the steering wheel test. I guess I'll do the coupler first and see from there. The car was in a minor accident many years ago according to the Carfax.
https://youtube.com/shorts/pIw1-ZfhWAQ?feature=share
https://youtube.com/shorts/IBAwJuNhL7k?feature=share
