I let the car get low on gas coming back from the airport late and it ran fine to the gas station. After filling up I went less than quarter throttle and misfired a bit. I let off and it was ok unless I gave it more than partial throttle. The snapshot code is below and the current PIDs are below. I am thinking injector is bad but could this level of throttle and low speed driving damaged the engine? Wondering if I should do a compression test before I start replacing parts.
