CLS Coupe (C219) Discuss the CLS Coupe.
Battery red problem
Old Nov 25, 2023 | 11:56 PM
HamadC63's Avatar
C63 2013 p30
Battery red problem
Hey guys I have an Cls 500 w219 2006
I am having problem with battery check i replaced voltage tensor and aux battery and principal battery and show me always battery check what to do ?
Old Nov 26, 2023 | 04:34 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
if youve had a bad oil leak the alternator starts to want out, the voltage regulator isn't always the fix but I agree it usually is.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Nov 26, 2023 | 12:19 PM
HamadC63's Avatar
C63 2013 p30
It's very strange because when I turn on the ignition, the cigarette lighter works to
It's very strange because when I turn on the ignition, the cigarette lighter works to charge and so do the internal lights, but when I start it, the cigarette lighter and the internal lights stop working.
Old Nov 30, 2023 | 05:53 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Please scan it for faults! A decent computer can also show you what is happening (voltages, loading amperage, etc) for the main battery and also AUX battery
It can also be the AUX battery relay (it sits under the cowel), or something like bad earth/grounding or Battery Control Module (BCM) etc.
Old Dec 8, 2023 | 12:20 PM
TSA's Avatar
TSA
S580 MAYBACH Z223
This problem mostly get caused by the BCM (battery control module). They get oxidated and then this problem appears on the dash.
Old Dec 14, 2023 | 05:56 AM
That is more the case at W211 chassis, the location of BCM in a W211 chassis is prone to water ingress. At W219 chassis this is not the case.
Old Sep 24, 2024 | 10:36 AM
michellebenz's Avatar
2006 CLS 500
isn’t it located in the boot … behind the taillight on the right I think ..???
