CLS Coupe (C219) Discuss the CLS Coupe.
Rpm sensors problem
Old Apr 21, 2026 | 06:28 AM
Robke1996's Avatar
Cls 550 w219
Rpm sensors problem
Hello, I have a problem with my CLS w219. The live parameters show these numbers and they do not change when stationary or driving. The ABS and ESP systems are working, but the steering wheel is much heavier. Where should I look for the problem?
Old Apr 22, 2026 | 11:40 AM
yagey's Avatar
2007 cls 63
Sounds like a CAN or module issue -
My suggestions:
disconnect battery for 10 mins
turn wheel lock to lock several times
clear codes
check the ESP module connections for water / corrosion
good luck and let us please know what it is when you solve it!
Old Apr 22, 2026 | 01:06 PM
Robke1996's Avatar
Cls 550 w219
My suggestions:
clear codes
Where located ESP module?
