CLS Coupe (C257) Discuss the CLS Coupe
Engine vibrates occasionally
Old May 8, 2021 | 02:56 PM
100stars's Avatar
e350 2014 CLS450 2021
I just purchased a new 2021 CLS450. It now has 250 miles. This is my first turbo engine car after a very long time (my last one was Mazda RX-7). long story short the engine caught on fire and I never purchased any turbo cars anymore. I have a 2018 Lexus LX570 and the V8 engine is buttery smooth. The Mercedes starts good but after 2~3 minutes in idling shakes for no reason. It does this a few times. Also on the road at the traffic light sometimes same happens. Has anyone experienced this?
Old May 27, 2021 | 02:35 PM
FrostedGlass's Avatar
2019 CLS 53
Could this be the ECO start/stop function? It will automatically switch off the engine if vehicle is stopped and certain conditions are met, and then automatically restart the engine as needed. This is rougher and more noticeable in some vehicles than others. It helps MB keep their fleet wide fuel consumption stats down.
There should be a button on the middle console to disengage. By default ECO start/stop is engaged on startup and the button shows a green light, pressing the button turns off ECO start/stop and the light goes out. The symbol on the button is "A" with an arrow around it in a circle. This feature is documented in the Owner's Manual.
Old May 28, 2021 | 01:19 AM
100stars's Avatar
This only happens in the beginning few minutes. On the road, all goes well including auto start-stop function. Then if I break the journey the car will do the same vibrations and then going smooth after 2~3 minutes. I can take it to the dealer but with my personal past experience with my 2014 e350 Mercedes, I do not want a dealer mechanic touching the car unnecessarily.
Old May 29, 2021 | 12:21 PM
petee1997's Avatar
...24 GLE53
Then the vibration will not go away and it’s notbnormall
Old May 16, 2024 | 04:06 PM
kdub's Avatar
2022 CLS450 2011 Boxster Spyder 2022 Bayliss V2
I have the exact same issue on my 2022 which I bought October 2023 brand new. I posted a different thread - didn't see this one. I took it to the dealer and they ran diagnostics but did not find anything. I feel like the problem went away temporaily after long road trips - but came back with around the town traffic. I noticed it again yesterday.
Old Aug 21, 2024 | 04:37 PM
lena44's Avatar
cls 450
Did anyone happen to find out what was wrong? This is currently happening to me and the dealer says they can’t find anything wrong.
Old Aug 21, 2024 | 08:49 PM
100stars's Avatar
My car has been at the dealer for the last five days. They are still trying to figure it out. I will update what they find out.
Old Aug 22, 2024 | 07:27 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
My first suspicion is loose hardware, fitting or connection.
Sometimes when hardware is loose, it can’t back out all the way from installation interference.
Anything loose will have a harmonic with engine vibration.
It could set up this harmonic vibration at certain engine speeds, in this case idle.
It might go away as the engine heats up, and seats better in its recess.
The best way to ferret out a vibration like that is to use a stethoscope and replicate as best you can the conditions where you routinely observe it.
Old Aug 27, 2024 | 01:20 PM
Helo pilot's Avatar
2023 E450 4matic 2021 GLE350
Engine Vibrates occasionally
I have a 2023 CLS450 and had a similar issue and took to my dealer in Oklahoma City. The shop foreman check my car and suspected it was the firing timing. He reset the timing and the problem went away. I only noticed shaking in the steering wheel when the RPM at an idle would go from 500 to 800 rpm. I can provide you with the name of the shop foreman if you need. Send me an email.
Regards.
Old Sep 7, 2024 | 04:25 PM
kdub's Avatar
Regards.
Thanks for sharing. I have my first B service comming up in October and will ask them to check it. Unfortunately I’m in San Diego and it’s an extremely high volume shop - hopefully they will try it.
Old Oct 18, 2024 | 10:15 PM
kdub's Avatar
I just had my service done - around 7,500 miles on the clock. Believe it or not the dealer was able to observe the issue! I told them about the timing reset. They said instead there was a software update and it resolved the issue. I just got the car back - so TBD if it’s resolved.
Old Oct 22, 2024 | 01:18 AM
NY_CLS's Avatar
I have a 2019 and experience the same issue. The dealer said they can’t find anything. I’ve noticed t’s worse in the winter and when gas is low. I would love to know what’s causing the issue. I think it’s related to the hold function since it seems to come and go when the car comes out of hold.
