Coolant reservoir boiling / bubbling
I have used Xentry to bleed the coolant system before and when i turned on the aux pump for that coolant tank, I can see that it pushes the liquid through the side hose and that amount of flow creates the "bubbling" effect.
So it's perfectly normal, and its not caused by any boiling. (the coolant on this side doesn't heat up as much as the main coolant reservoir tank.
Hope this helps!
Hope this helps!
