CLS Coupe (C257) Discuss the CLS Coupe
2023 CLS-450 SERVICE A
Old Dec 26, 2024 | 04:24 PM
number003's Avatar
2013 SL-550
Has anyone tried the
BlueDriver BlueDriver
for Clearing the SERVICE A & B..??
YES.. .I've tried the following without success.
1) Ignition position 1
2) Home button on 'Trip'
3) Press Home button ONCE. (Displays scrolling options)
4) Hold Ok for 5 seconds (Should switch back to TRIP screen.
5) Hold Home for 5 seconds. (Displays scrolling options THEN back to TRIP)
6) Hold Ok for 5 seconds and release. (Shows Vehicle data, brake pad, WORKSHOP).
Any feedback or alternate device that works would be appreciated.
Old Dec 26, 2024 | 06:56 PM
W205C43PFL's Avatar
Originally Posted by number003
Has anyone tried the BlueDriver for Clearing the SERVICE A & B..??
You shouldn't need a scanner to reset it regardless, it is sometimes tricky to get in that menu, keep trying, try using this method, also check the pdf file attached there: https://mbworld.org/forums/e-class-w...indicator.html
Old Dec 26, 2024 | 07:00 PM
W205C43PFL's Avatar
Here are two more PDFs that might help: https://mbworld.org/forums/w213-amg/...ml#post8989074
Old Dec 26, 2024 | 07:07 PM
W205C43PFL's Avatar
This PDF : https://mbworld.org/forums/e-class-w...ml#post8422196
also try putting the key in the marked spot.
Old Dec 27, 2024 | 10:35 AM
number003's Avatar
2013 SL-550
Got it and i'll try today.
G550 SERVICE INDICATOR RESET.
t.pdf
Old Dec 27, 2024 | 11:40 AM
W205C43PFL's Avatar
Hopefully it works for you.
Old Dec 27, 2024 | 11:43 AM
W205C43PFL's Avatar
Stay tuned to that thread: https://mbworld.org/forums/e-class-w...dicator-2.html
