CLS55 vs E55 wheel fitment question
Old Mar 10, 2010 | 02:22 PM
KLR CLS's Avatar
CLS63 PP
Do the wheel fitments for an E55 fit a CLS55 without issue? I am looking at buying a set from a member who bought them for an E55, but did not end up using them. Will they fit on a CLS55 with P030? They are 19" RS wheels.
Thanks for assistance in advance..
Pete
Old Mar 10, 2010 | 04:31 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
CLS wheels have an ET of 25 front and 28 Rear, so they have a wider track than E's.
infact you oftenly find E-class people using CLS's wheels ..
if you'll do the contrary, it is highly probable that the inner side of the wheel will contact with braces ...
Old Mar 10, 2010 | 06:06 PM
detail-king's Avatar
Former Vendor of MBWorld
Mercedes Benz CLS63 AMG
The front will be no problem. The rears will most likely need a 10mm spacer as they will sit it too far and most likely hit the caliper. If you use a hubcentric spacer, you should be good! Find out what offsets and widths the wheels on the E55 are and I can help you figure the rest out.
Old Mar 10, 2010 | 06:37 PM
dyno's Avatar
I would not be so sure even for front wheels,
especially if your going with aftermarket wheels
look here how close the caliper is (and the same the inside where braces are)
and yes, this is not an OEM wheel, but its ET is still 25 as the oem value
and further, it's even a bit larger 9" vs 8.5" stock ...
Old Mar 10, 2010 | 09:40 PM
KLR CLS's Avatar
CLS63 PP
Offsets are Et30 fronts et35 rears . They are monarch RS63's
