Launch Control Trouble
Old Sep 9, 2015 | 10:52 AM
roxind's Avatar
AMG GTS 2015
Hi everybody,
Here is my problem, every time I try a race start / Launch control, the process is successful up to the "Accelerate" screen. But when I do so, the launch is stopped and the screen read "Launch start Impossible", whatever I do.
Anyone has encountered this problem before?
Thank,
Old Sep 11, 2015 | 02:43 AM
F456 V12's Avatar
17 SL550 (Designo Edition), 08 C300, 13 Mini Cooper, 17 Macan GTS, 18 720s
You need to mash the accelerator pedal to the floor. If you try to match the RPM's to the Launch RPM's the clutch will overheat and the launch will fail.
My guess,
MB
Old Sep 11, 2015 | 12:11 PM
roxind's Avatar
AMG GTS 2015
Whaaoouu, I'll try to "mach" it next time, but I sure wasn't particularly slow at building rpm, but yeh, in the same time, not maching it.
I'll definitely try to be quicker on the pedal and report if that do the trick...
thank for the tip...
Old Sep 12, 2015 | 06:00 AM
roxind's Avatar
AMG GTS 2015
Follow up,
That was it, I wasn't quick enough on the throttle. I had never use a launch control before, and couldn't find a clear explanation of the process. Mercedes should make that last point very clear in the descriptif, accelerate is not enough...
Thank again F456 V12...
