Ground Clearance
Old Mar 21, 2017 | 12:07 PM
guynamedsean's Avatar
2017 AMG GT
Originally Posted by boosting1bar
My GT struggles with the underground garage I have to park in at home. If I get the approach and departure angle perfect the center of the car won't touch on entry/exit at the top side. If I get it wrong the center cross member rubs, haven't actually touched the side skirts but I'm always afraid it will. At the bottom there is no angle I can come in that it doesn't rub. I cut it as sharp as I can at the bottom but it always rubs. The part that rubs is the part of the lip that points downwards and the front portion of the lip sticks out far enough that you can't see the rubbed area.
I would move or lease second residence to keep GTS and other woman maybe.
Old Mar 21, 2017 | 12:44 PM
boosting1bar's Avatar
cars and stuff
I've rented out a couple spots in the parking garage a block down so I don't have to lol
Old Jun 8, 2017 | 07:52 PM
06032's Avatar
2016 AMG GTS Edition 1, 2007 Alpina B7, 1987 560SL, 2011 E350 Wagon, Ural Patrol
Very helpful to see the effect of a 1.5" drop and level. Looks just about perfect.
Old Jun 8, 2017 | 09:16 PM
descartesfool's Avatar
AMG GT-S, AMG C43, Ferrari Roma, Maserati MC20, Genesis GV70 Electrified
Originally Posted by California John
An interesting point is that with the Dynamic Plus Suspension package (P71) additional negative camber is added to the front wheels. How much is not public information I don't believe. Part of the "secret sauce"
No secret. It's part of the factory alignment procedure from the manual, which was posted by Alexfor8 in his maintenance thread.
https://mbworld.org/forums/amg-gt-gt...ml#post7134700
Front camber for the regular model is 1 degree 42 minutes
Front camber with P71 Dynamic Pack is 2 degrees 6 minutes
Rear camber is the same for both at 1 degree 51 minutes.
And by the way, dropping the car 1.5" is going to really screw up the suspension geometry, in terms of camber curves as the suspension moves up and down, and also toe variation, bump steer, etc. Might be OK for cruising on the street, but I would surely not do that for a car run on a race track.
Old Jun 8, 2017 | 09:24 PM
AMG 17GT's Avatar
R Nine T
This man runs on tracks. I would follow that advice.
Old Jun 9, 2017 | 08:21 AM
06032's Avatar
Great insight. Aside from aesthetics, sounds like it's counterproductive to lower this car. Suspension 'as is' (with DPP, anyway) is already '98%' with the benefit of not needing to worry excessively about uneven driveway approaches or potentially insurmountable alignment issues.
Old Jun 9, 2017 | 10:18 AM
  #32
larrymz3's Avatar
AMG GTS Edition 1
Agreed!
Old Jun 9, 2017 | 05:18 PM
  #33
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
Except that our OEM cars look like they are on stilts. To Descartes post, at least RennTech, KW and Weistech coilovers are adjustable, unlike H&R. I wonder if these guys would like to comment on the suspension geometry issue??
