AMG GTS Tuning piggybacks and OBD2 Boost pressure
Meanwhile i did some experiments using a perfomance box (vbox) to have an idea of the car performance and to compare stock numbers to after installing the module.
0-100 Kmh in 4.0 with wheelspin using race start with Traction off
100-200 Kmh in 7.3
The run was in 30 degrees Celsius and using Michelin pilot super sport which came with the car so they are 2 year old tires which drove on them 20,000 Km LOTS OF WHEELSPIN ! I think these are good results in this condition.
This is slow i think.
I run from 100-200 a 7.4 without any tuning or something. Fuel is Aral 102.
For better results you have flash complete ECU. This piggyback is not the best solution in my eyes.
My Friend my car is totally stock i didnt tune it or anything still i didnt receive the tuning module yet, and im running the test in 30 degree Celsius on 98 Ron Fuel which is 93 in America pump fuel so its Super results i bet your in much colder place than i am and better Humidity levels.
Yes that what i was promised i hope to get that number it will be great. but its not a huge improvement comparing with the M157 engine on e63 and Cls63 with a tune they drop from high 7s and even 8s to mid to low 6s range so its a true improvement, i guess bigger engine has many advantages but cutting 0.7 sec is not bad too.
The launch control procedure is also very quick to do once you practice a bit. I am glad MB is even making simpler ala Porsche on the E63.
The only issue I have with race start is that it gets disabled after 5 seconds and there's no way of knowing how long the light will take
so it's a crap shoot so I don't use much.
LOL .. Be positive and im not in a rush the car wont fly. the important thing is at last i get what i paid for.
ill leave it till tonight to adapt and the weather gets cooler and ill try running proper runs and provide results ! for sure i need better tires to give it justice lots of wheel spin even while accelerating from 80-100 kmh !
here is the vbox result. before the tune i used to get 7.3 on same road and around the same temp
Thanks !! Yeah now i know what you have been going through with the wheel spin ! Haha
