Strut Braces replaced
Dealer diagnosed as: LI62.30-P-061211. "Strut braces cracking and popping". Replaced uppers and retorqued both lowers. Black-colored struts replaced with shiney aluminum and different part #'s (190-620-87(88)-01. Also inspected for the legit recall, tranny seal leak but all is well on that one.
Apparently this strut issue is pretty common. Anything else to keep a watch for?
Posting as a heads up....but interesting that no one else here has experienced it yet.
The strut defect is unmistakable and repeatable. Loud like a hammer tap to the frame. Sounds similar to a loose upper shock mount. Located close to the firewall. Not visible from under the hood. 2-3 hours labor to replace both sides.
