RAISE FRONT END
Old Jan 13, 2018 | 06:48 PM
ronrpg's Avatar
2018 amg gtc
RAISE FRONT END
HAVE 2018 MB AMG GTC WOULD LIKE TO RAISE FRONT END
ANY IDEAS OR SUGGESTIONS APPRECIATED
Old Jan 13, 2018 | 09:29 PM
California John's Avatar
2022 AMG SL63
So that you don't scrape it? Do you want to be able to raise and lower it at will?
Old Jan 13, 2018 | 09:45 PM
MalibuScott's Avatar
2025 Lucid Air Grand Touring, 2022 F-150, 1926 Rolls-Royce SSG roadster
Originally Posted by California John
So that you don't scape it? Do you want to be able to raise and lower it at will?
Lotsa places in East L.A. could help with that.
My 2001 CL55 had a button where you could raise or lower the car in three steps about an inch and a quarter. Helpful at nasty parking bumper stops and steep driveways. It was also the first expensive system that failed after my warranty ran out. It couldn't "stay up" and had to be pumped up before I could leave my garage.
Old Feb 16, 2018 | 05:59 PM
ronrpg's Avatar
2018 amg gtc
no id leave it at the new height
ronrpg's Avatar
2018 amg gtc
this does not have that option
Old Feb 16, 2018 | 06:19 PM
Vic55's Avatar
Administrator
Your CL had ABC aka air suspension, his car is on springs. The only way is find a spring that actually RAISES the car and there isnt a such thing at least not in production. People want to lower their cars not raise hence lowering spring companies.
The OP will have to find a spring that fits the perch that pushes it up but you will have way more issues that worrying about scraping if you do this. You will have the wrong springs, wrong rates, and the car will lose its entire handling and suspension identity.
Old Feb 16, 2018 | 06:24 PM
Wolfman's Avatar
Super Moderator
Can coilovers be used to raise the suspension? If so KW? I assume the GTC doesn't have an adjustable suspension like the GTR...
Old Feb 16, 2018 | 07:12 PM
Vic55's Avatar
Administrator
Great question and I did look into that--- they only offer lowering ranges but the spring cant get any more open than it can. Unfortunately a non adjusted KW spring is about the same height as an oem spring.
