Full Build GTS
#52
Cool but what were the intake charge temps at sustained full boost before [stock] and after the larger charge coolers..?
#54
Again do you have any "real data" to compare this charge cooler against the stock charge cooler ?
I have no idea what "which setup" you are referring to.
What are the pre-charger cooler temps and post-charge cooler temps both stock and modified ?
California John (07-04-2018)
#55
Also did you change the stock heat exchangers for these larger charge cooler ?... Come on dude let's see some "real data"..
