Hardwired trickle charger
Does anyone have experience with hardwiring the MB provided trickle charger on the GT vehicles directly to the Li ion starter battery under the hood? It came this way from the dealer on a new vehicle and there is a " Battery not charged" warning sign in red on the instrument panel despite charging the battery to full charge.
Under the hood. Attach red clip to red terminal on battery, Black on grounding nut.
If using eyelet adapters, loosen nuts on battery, slide eyelets over corresponding color over corresponding terminal and replace nuts to secure. This is more permanent solution . Just disconnect cable at connector when done and leave the short cable attached and in the engine bay.
The connectors were tight. The green light showing full charge was in after an overnight charge.
Could it be a faulty alternator? I mean the car is brand new. It's baffling.
