Hard track use upgrades
#451
With TIKT ducts You completely remove the original backing plate (heat shield) as that area is covered with the "duct".
I will also point out once again that the proper duct is doing far more than just directing some air towards the rotor... I already explained (in this thread I think) the importance of separation of rotor inlet and exhaust to prevent hot air being sucked back into the rotor, thus reducing the cooling potential of the flow generated by rotor vanes. That combined with the forced air induction to the rotor makes TIKT ducts so much more effective compared to any other solution which just guides the air towards the rotor with air guides and deflectors which can't form a proper closed "duct"
I could probably make an explanation video on functionality and installation... Let me know if that is something You guys want to see.
DriveAMG (03-24-2020)
#452
The following 4 users liked this post by Draptec:
#453
I think this will answer many questions...
https://www.youtube.com/watch?v=4QDl2QGUOmg&t=77s
will do the rear ones as well.
There was a video for rotor temps on track with each side different, which seemed like quite an unbalanced setup to drive Any more data on that with OEM brake shield and Tikt duct installed with both wheels being the same, in terms of Delta T. It would be nice to have data temperature logger charts for a lap or two once the brakes are up to full temperature. How is the pad longevity affected?
#455
That was fantastic! Thanks. Great design work, and very nice fitment with tight gap to the rear of the rotor to close off re-circulation.
As for the comparison of OEM setup and TIKT upgrade, well You can't compare these two... For any real track use OEM setup is not nearly sufficient and once You have a driver who is real fast and ignores fade - rotors are destroyed. TIKT ducts on the other side perform well in the hard track conditions but the data We gathered has nothing to compare with - we haven't came across any other upgrade which is functional to measure and compare the efficiency... (We tried a few options during development and We have a PRO which also doesn't work)
As fore the pad longevity it is not significantly improved. So when You brake hard You wear the pads, that is inevitable (until we make some magic ducts) but You don't destroy the pad with overheating and the rotors definitely last much longer.
The following 2 users liked this post by Draptec:
California John (03-23-2020),
thebishman (03-23-2020)
#456
Thank you!
Well I’m sold on a pair for the fronts. My question is why do these need to be made of Carbon Fibre? Also how can I get a set here in Toronto?
#457
Let's cheer up the thread with some nice photos of the current test car...
The following 3 users liked this post by Draptec:
#458
With this tight fit design they need to be heat resistant as much as possible. As You could see in our testing video temps go up to 800-900 and that would simply melt down any other plastic. A good alloy would be even better in terms of heat but the shape is just way too complex to form. Also carbon composite is low weight which is an advantage. I'm sure You can have them in Toronto but You'll have to contact TIKT directly.
#459
V8ray (05-22-2020)
#460
As promised, here is the video explanation of installation procedure and function of TIKT Performance AMG GT rear brake ducts:
If anyone has any further questions I'm here to answer them all
DriveAMG (03-24-2020),
#462
Tikt Ducts
Hello all. Hope this minor update finds everyone well. So I heard from Tikt and also from Vengeance. At this time I’m only interested in a set of fronts. The quote from Vengeance I thought was a bit high considering they are passing on all the shipping costs plus adding taxes to an out of country order. Tikt on their website has the fronts for €1490 which includes 19% VAT. If the VAT is removed it’s approx €1206 plus shipping only unless I’m missing something. Shipping from Tikt was pretty expensive I believe but I think ordering from them direct would be the way to go. I’m up here in Toronto and I think I could be interested in sharing shipping if anyone local wants to order with me when this nonsense settles down in a few weeks. Any thoughts? Thanks in advance.
#464
Former Vendor of MBWorld
with castrol SRF prices up and harder to find? anyone try Ferodo super fluid? Im may try that next (have a few bottles of SRF left).. I think Im done with RBF660..
https://www.essexparts.com/brake-flu...ng-brake-fluid
#465
I stopped using RBF a few years ago
thebishman (03-25-2020)
#466
I bought a set and they work great! Before I picked them up I ran a single track day and boiled the high temp fluid. Put these on and never looked back, not a single failure over the remaining 2019 season. So glad I saved my money and bought these deflectors.
#467
‘24 BMW iX M60
Bish
#468
#469
‘24 BMW iX M60
I believe that Jeff Ritter at AP Racing USA has stated that for most folks R3 would be fine, but if you don’t mind spending more money, R4 is their ultimate brake fluid.
I used Endless 650 last year in the car and it was excellent. No fade and always a firm pedal.
Bish
#470
#471
With a 200000$ GTR on the Track fast guys spend 3000-4000$ per day just in Tires and Fuel... without proper ducts it can be much more when You have to replace the rotors. Is duct price really an issue?!
MG1422 (03-26-2020),
thebishman (03-26-2020)
#472
I would say it's not about how often You go to the track... It's about how fast You drive on the track. For most of the guys stock setup with good braking fluid will be just fine, but for those who really lap good times even Tikt setup is almost on the limit.
Draptec (03-25-2020)
#473
Rears will be available soon.
#474
Love the videos. Have a question. Do the front pick up debris? And will they hit the disc surface?
#475
The plastic deflectors offer a few advantages over the full on carbon fiber ducts. You can find something similar in many OEM applications from most 911's, to Mclarens, to the Civic Type R. Why Mercedes didn't include it in our cars from factory is a mystery. The Ansix Auto deflector is made from polypropylene which is a very tough material. What this means is it can be bent and deflected a lot and not crack, break or yield. This is especially important because the deflector hangs low and would have the chance of being hit by foreign objects. For a full on race application, the Tikt ducts are definitely nice however a fully enclosed duct like that may not be the best choice for a daily driven vehicle. It can have the tendency to collect rocks and cause rattling whereas a plastic deflector will not have that issue. And finally, the difference in price is very apparent. Both choices will provide a significant improvement of cooling for your brakes, what you option is about weighing the pros and cons.
Bill, glad to hear they worked out well for you!
More than 50 cars have been equipped with TIKT ducts and most of them are used on the road as well... not a single one broken so far, not even the ones that went off the track in to the gravel.
"Both choices will provide a significant improvement of cooling for your brakes, what you option is about weighing the pros and cons."
-Have You performed a comparison test? Do You have any solid data behind that statement? I would love to see something like this:
Anyway, Ansix ones are cheap enough for anyone to try. If it it's not sufficient it's not a big waste of money and You can always upgrade to the TIKT ones.
And Yes, TIKT ducts are designed primarily for hard track users with performance in mind. For those who just drive the car around this is not necessary. Stock setup or deflectors like PRO upgrade or Ansix will be just fine.
LAsunset (06-12-2020)
