COILOVER/SPRING MOD THREAD
The stiffer KW rear race springs [optional] are exactly what the car needed to eliminate any feeling of understeer in my opinion.
Here in atlanta, I’m running into installer issues and have reconsidered renntech sleeves from a Benz dealer as shim kit seems to be in order. I was told by renntech engineer that rears are sprung less and fronts more than stock.
And then then there’s the weistec sleeves which have progressive front springs in that the first few inches of travel up front have a smaller diameter spring.
@ronin_amg Do you know what spring rate or part number you went with for the "race" set of rear springs? From the looks of it, the standard setup for the KW HAS is already stiffer than stock in the rear with 50N/mm fronts and 60N/mm rears. How does it ride in Comfort mode? does the rear oscillate from the higher rate?
@AHI I read the other thread you started. About the KW's, you said it rode well at a higher ride height but it wasn't good at a lower setting. Do you think its possible that you were hitting your bump stops which caused some unpredictable behavior? Or do you think it's just that the dampers were under-damped for the higher spring rate of the KW's and causing oscillations?
After install and parts I’m looking at 3500$, for an inch lower. Under most circumstances I would pay that for another inch, just not now..... yeah yeah.
I also looked at the Weistec setup and they're running VERY high spring rate rears. The fronts are maybe like 30% stiffer but the rears are more than double the rate of stock. I'm going to stay away from that setup. That's likely why 300blackout mentioned the shift in comfort.
KW uses 50N/mm front and 60N/mm rears which is quite close to stock. If I find I don't like the balance and want to run a softer rear, I can always swap the front and rear springs. The only effect that will have is it will limit how high or low my car can go but it's only a 10-20% height difference. There's no way you can swap the front and rear springs for the Renntech setup because of the lack of helper spring in the rear.
I think the best bet for me is the KW HAS, its more flexible (because I can swap front and rear springs) and it also can be had for ~$1200 shipped which is a good $300+ cheaper than the Renntech setup.
Here are the KW rear springs, they are interchangeable with the fronts if you want to stiffen up the front end....
I had the alignment included in the final price, but what would you believe to be the ideal alignment specs with these coilovers ?
Just verify the dealer has the shims on hand, as back in fall of 2017, there were only 3 or 4 boxes available in USA, so I had to have 1 set transferred in from west coast the other from East coast when we did my alignment.
As far as specs, via memory I don’t recall, think I may have print out packed away somewhere, but I believe we were in the higher side of the “green” box for camber....you’ll see what I mean when car on rack, there is “red” “yellow” and “green” to help with adjustments that are in the racks screen guiding tech towards acceptable specs.....assuming the GTS software is being used.
If you go with a combo street/track alignment of around -2.3 to -2.5 camber all round, two boxes of shims should be enough especially if ride height is lowered. If you want to go more aggressive for primarily the track, then you’ll probably need four boxes of shims; (they aren’t cheap btw).
I’m running -2.5 camber at all four corners and am very happy with it for all purposes. Can’t remember my caster and toe settings but I didn’t want the car to be ‘nervous’ on the street so they aren’t too aggressive.
Bish
