UPD AMG GT air intake kit and filter special
Old Jan 16, 2019 | 05:20 PM
AHI's Avatar
AHI
AMG GTR
Originally Posted by C’est 063
They worked very well and the filters were dry. I have the Weistec dry filters for the GTC but I wonder if the spacers would work with these and if so could I get a pair. For the record I would have ordered the UPD set for the GTC but I won’t run oiled filters anymore as I have had service issues with them in the past... thank you.
I use Weistec filters with UPD spacers. Its tight, but it works.
Old Jan 16, 2019 | 06:29 PM
DriveAMG's Avatar
2019 E63s
Cool!
thanks!
Old Jan 16, 2019 | 06:59 PM
Jan AMG's Avatar
The best or nothing
Originally Posted by Exotic-metal55
We are doing a year end sale on our AMG GT 4.0 litre air intake kits and also just performance high flow air filters. Air intake kit are regularly $450.00 and on special for $350 plus free shipping in the mainland USA. Kits come with high flow air filters. If you just need high flow air filters, they are on sale for 139.00 per set and free shipping (list price 175.00) . Easy to install and keeps the factory look. Message us or order online.
http://ultimatepd.com/2016-and-up-me...-kit-c190.html
Picture of air box inlet.
Factory air box with black anodized kit installed with high flow air filters.
Picture of factory air box with black aluminum anodized kit installed with high flow air filter.
Do you have a kit for M157 and do you ship to Europe?
Old Jul 6, 2020 | 04:30 PM
mbjj57's Avatar
amg gtc 2020 bk
Originally Posted by AMG 17GT
This mod really works along with secondary resonator delete. Increased volume of air both ways.
did you install the airbox spacers on your car?
Old Jul 6, 2020 | 04:37 PM
AMG 17GT's Avatar
R Nine T
No just weistec filters.
Old Jul 6, 2020 | 05:31 PM
mbjj57's Avatar
amg gtc 2020 bk
any noticeable improvement with the Weistec filter only , performance and sound wise ? ( without tune nor secondary cat delete).
Old Jul 6, 2020 | 05:33 PM
  #32
kumizi's Avatar
Designo White AMG GTS
I want to do a before/after dyno with this kit on my GTS but it's too damn hot right now in Texas. Going to wait until September.
Old Jul 6, 2020 | 05:34 PM
  #33
AMG 17GT's Avatar
R Nine T
any noticeable improvement with the Weistec filter only , performance and sounds wise ? ( without tune nor secondary cat delete).
Well I did this filter change after cat delete, but I did notice the car was breathing alot better and was spooling up faster. The stock filters were more than twice the thickness, so I just believe it’s an obvious mod to make.
Old Jul 6, 2020 | 05:40 PM
  #34
mbjj57's Avatar
amg gtc 2020 bk
got it. good to know.
I am wondering if it is worth it to install the Weistec filter along the "air box spacer" ...?
Old Jul 6, 2020 | 05:45 PM
  #35
AMG 17GT's Avatar
R Nine T
Secondaries are the much bigger mod and same $$$.
Old Jul 6, 2020 | 09:20 PM
  #36
mbjj57's Avatar
amg gtc 2020 bk
I see...
I just don't want to mess with the exhaust for now ( cutting the pipes) as I solved the "sound issue" by adding the "cete exhaust valve module" on my car. 2020 gtc
Old Jul 8, 2020 | 02:48 PM
  #37
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We have the spacer kit and high flow and filters on sale for the M178 AMG GT. http://ultimatepd.com/2016-and-up-me...-kit-c190.html
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 8, 2020 | 08:55 PM
  #38
Skilly's Avatar
2020 McLaren 720s Spider
agree - most of the stuff that I have seen says the paper filters aren't really that restrictive - the spacer by itself might be a better improvement (but you can't typically get that without the "kit"
Old Jul 8, 2020 | 10:02 PM
  #39
jn66's Avatar
AMG GT R Pro
Anyone install these on a GTR? Are intakes the same?
Old Jul 8, 2020 | 10:38 PM
  #40
DriveAMG's Avatar
2019 E63s
Yes it’s the same.
I have the Weistec filters on my GTC and there is a bit of a difference in the butt dyno but I mostly got them because they are washable and they seem to be the only dry high flow filters out there. That said I did run the UPD setup a few years ago on my 14 e63 and it felt good too. More air can’t hurt.
Old Jul 8, 2020 | 11:56 PM
  #41
jn66's Avatar
AMG GT R Pro
thanks!
Old Jul 9, 2020 | 12:25 AM
  #42
DriveAMG's Avatar
2019 E63s
Happy to help
thanks!
You’re welcome!
Old Jul 9, 2020 | 04:40 AM
  #43
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Guys, there is no HP difference with this. Zero, ziltch. A cold air intake is one thing, but lifting the filter is not going to improve air flow at all. Even if it gave some margin of improvement which there is no proof that it does everyone would be doing it, A car with 500-600hp is not going to feel a 5hp improvement nor is it going to rev different or more freely. A turbo is going to force air through at what the computers allow. With a tune it’s still what the computers will allow. RENNtech and others are getting 700+hp with stock intakes. So this is not helping it at all. What do you guys think is more restrictive, the intake which has no viable reason for restrictions or exhaust which has a ton of restrictions due to co2 numbers and smog?
Old Jul 9, 2020 | 11:06 AM
  #44
Skilly's Avatar
Completely agree BUT just a couple of notes. 1. the spacer can in some cases provide for more rounded corners or air surface access; the paper filters themselves are not more restrictive. By and large it's snake oil unless you are talking about cold air etc. (to your point, mine are stock). 2. You are spot on with the exhaust but at some point there are diminishing returns there too. If you take out too much back pressure in the exhaust that hasn't been adjusted with a tune or increased flow from the engine, you actually lose torque...for example, try downpipes without a tune...underwhelming (although, Im not sure who would actually do that). Balanced back pressure is a part of this equation.
Old Jul 9, 2020 | 10:09 PM
  #45
DriveAMG's Avatar
2019 E63s
For me it’s an an environment thing first and performance benefit second if any. I’m pretty sure these filters with spacers were dynoed and shown to offer more than 5hp but if memory serves it was in the previous gen 5.5l biturbo v8...
Old Dec 11, 2020 | 05:16 PM
  #46
GTS67's Avatar
2016 AMG GTS
I want to thank the people at Autoscope in Plano for getting me in last minute for before and after runs; with the stock filters on my GTS and then the Weistec filters. They were done on a Dynapack dyno. The car is bone stock besides this.
The good news is the first two runs were consistent at 503hp at the wheels and 500 ft/lb of torque! I knew they underrated the car; but that’s a lot. The disappointing part was zero hp gain with the new filters. To be fair, I am going to redyno in a week to let the ECU adjust and see if that makes a difference. Who knows.
Old Dec 11, 2020 | 05:44 PM
  #47
Skilly's Avatar
I think HP is the wrong focus, but it isn't to say that there couldn't be improvement in another area.
There is turbo lag on these cars which with better air flow could be offset - not sure if that's the case with this lift thing; however cars like the 911 TT can gain a huge amount of benefit from addressing the chokehold that the plenum and y-pipe have on the system. And, while it seems like an expensive (2K range) mod it transforms the car and addresses a great deal of turbo lag. So, less about HP and more about getting to said HP a LOT more efficiently.
Old Dec 12, 2020 | 12:32 PM
  #48
dyc1077's Avatar
2004 sl600
Wow. I’m looking at the torque curves, I see either huge gains or huge losses between 3000 and 4500 rpm. Can you share which color bands are which? Orange/magenta with after market filter and glue/green with stock filter? While peak numbers don’t look much different, torque band is shifted a few hundred rpm or gains of about 20 ft lb.
Old Dec 12, 2020 | 05:25 PM
  #49
GTS67's Avatar
2016 AMG GTS
Good eye! After looking at the overview page, the green and yellow are the first and second pulls with the stock filters, and the magenta (my GF confirmed that’s the color. I had to ask) and the turquoise are the first and second runs with the “upgraded” filter.
Old Dec 12, 2020 | 11:57 PM
  #50
dyc1077's Avatar
2004 sl600
well there goes my thoughts then. No discernible difference between stock and aftermarket filter
