Anyone considered 2018 front bumper for 2016 PRE LCI GTS?
thanks!
I sent an email to inquire about installation and here is what they responded back:
you need a good body shop for the installation because there must be made 2 modifications.
1. The Diameter from the park distance control sensor holding brackets in the Facelift bumper must be made a little wider
because the before Facelift Sensors from your car have a bigger diameter as the holding brackets in the Facelift Bumper
2. If your car has the Radar Control Sensor, the holding bracket from this Radar Sensor must be cut out from your OEM Bumper
and must be glued in the Facelift Bumper at the same position
I talked to the local body shop and decided against it.
