Coupe/Roadster
I’m debating deleting my Secondary Cats...
Old 05-27-2020, 10:53 PM
  #51
dlefty's Avatar
/////PRO
Originally Posted by t3flondon
Someone chime in if I am wrong, there is nothing wrong with being a perfectionist, in my opinion, and I have owned and modified a lot of high end vehicles over the last 35+ years, that mod no matter what you use, pipe, material etc, is not going to make much difference in performance or sound, upgrading down pipes, exhaust system will, but not just the pipe used for removing secondary cats, just make sure that the weld is good but sounds like he is a perfectionist. lastly there is a debate on if the pipe should go over or inside the removed cat ends, and X pipe is another debate that can go on as well.
You are not wrong. Go downpipes or leave it alone.
stock “cat-back” exhaust on this car flows plenty for big power so no need to change that.
Old 05-27-2020, 11:58 PM
  #52
t3flondon's Avatar
2003 CL55 AMG 2019 C300 Coupe 2017 AMG GTS 2020 A 220
You missed the point, he is doing this for sound not flow. The reason we delete the cats, is because it's a cheap mod to get a better tone that's all, I was just stating if you are gonna spend more money, do it for better exhaust or down pipes and not on a replacement pipe.
Old 05-28-2020, 07:27 AM
  #53
tblountman's Avatar
GTC Roadster
Anyone know the diameter?
Old 05-28-2020, 07:44 AM
  #54
DriveAMG's Avatar
2019 E63s
As the OP on this thread
I decided not to cut mine but instead went with a valve module instead. I am happy I went this way because I do track my car and with increasing noise restrictions I’m able to have my cake and eat it too. Too many cars I know of (not necessarily AMG) have not been allowed to run on track because of noise violations. The module is I think at this time the ability to not only have your cake, but eat it too.
Old 05-28-2020, 08:20 AM
  #55
AMG 17GT's Avatar
R Nine T
Removing secondaries just reveals the original engine sound much like taking out the particulate filter. Some days my GT is downright quiet. In addition, those cans will reach 1500 degrees each, which obviously has downsides.
Old 05-28-2020, 08:48 AM
  #56
DriveAMG's Avatar
2019 E63s
You’re right
there is a ton of heat there too... I forgot about that but so far so good
Old 05-28-2020, 10:27 AM
  #57
Skilly's Avatar
2020 McLaren 720s Spider
Did you go with the RENNtech module? They were claiming that it opens up the valves 100% and that the factory setting when open holds back to about 70%. Love to hear your findings.
Old 05-28-2020, 10:47 AM
  #58
t3flondon's Avatar
Also removing them makes the car a bit lighter, not much but every pound counts right?
Old 05-28-2020, 10:52 AM
  #59
DriveAMG's Avatar
2019 E63s
I went with the no name...
version of the Renntech module. I was able to get it shipped from the UK to Canada. I would say if you can get it then do it. It’s worth it 100%. That being said if I wasn’t tracking my car I would probably have removed the secondaries by now...
FWIW, the module installed in under 5 min and works like a charm.
Skilly (05-28-2020)
Old 05-28-2020, 01:54 PM
  #60
Skilly's Avatar
with it fully open is the crackle/pop more pronounced? Or is it just generally louder?
Old 05-28-2020, 02:31 PM
  #61
MG1422's Avatar
GTR
Just cut the cats!
Old 05-28-2020, 02:39 PM
  #62
DriveAMG's Avatar
2019 E63s
Both
louder and more crackle
  #63
Skilly's Avatar
Anybody using HighFlow cats (like RENNtech 200 CEL) and avoiding CEL or Smog issues?
Old 05-28-2020, 02:40 PM
  #64
Skilly's Avatar
​​​​​​​exactly what I was hoping to hear!
Old 05-28-2020, 05:46 PM
  #65
AMG 17GT's Avatar
R Nine T
If you are really tracking the car, choosing a flap module over a pure exhaust mod that increases flow makes no sense. If as you say it opens 100% and is louder Then how would that cure noise on the track?
A lot of you are overthinking this, if you don’t like the mod just reinstall the secondaries.
Old 05-28-2020, 05:50 PM
  #66
DriveAMG's Avatar
2019 E63s
It makes perfect sense
If you are really tracking the car, choosing a flap module over a pure exhaust mod that increases flow makes no sense. If as you say it opens 100% and is louder Then how would that help on the track.
1. I would rather spend 5 minutes removing the module then half a day at a shop getting things put back to they way they were if the secondaries are removed.
2. Noise regulations at the track are becoming more commonplace and I think losing $5-700 on a track day because it won’t pass because I’ve removed my secondary cats vs pushing a button and going back to stock mode is valuable. Besides up here the cost is the same.
3. It wasn’t done for the track. It was done purely for noise and fun. My car is plenty fast already.
I will post up some videos later
Old 05-28-2020, 05:57 PM
  #67
AMG 17GT's Avatar
R Nine T
But you can close the flaps with the press off a Factory button if noise is a problem. Makes no sense.
Old 05-28-2020, 06:30 PM
  #68
kumizi's Avatar
Designo White AMG GTS
Lol so much controversy on the forum recently.
I think he's saying with the cat delete the car might not pass noise restrictions on the track.
But you're right. The EVM has nothing to do with cat delete. WOT at the track, the car wont be any louder with the EVM. It will sound the same. The benefit of the EVM is you can make the car louder at idle or part throttle cruising around town.
AMG 17GT (05-28-2020)
Old 05-28-2020, 06:51 PM
  #69
AMG 17GT's Avatar
R Nine T
Just a lot of flawed logic on choices. Another perfect example of people justifying purchase.
Old 05-28-2020, 07:05 PM
  #70
DriveAMG's Avatar
2019 E63s
Actually it’s not flawed...
noise testing at the track is not done flying by at full throttle. It’s done at idle at a prescribed distance. In these conditions the car would be louder with no secondaries and might not pass. Thus having the ability to shut off some noise with the EVM is more valuable to me.
As mentioned earlier the cost is exactly the same here so that is not an issue that needs to be justified
Lastly at no time did I suggest one is better than the other. I merely said the choice I made satisfied me.
Old 05-28-2020, 07:09 PM
  #71
kumizi's Avatar
noise testing at the track is not done flying by at full throttle. It’s done at idle at a prescribed distance. Thus having the ability to shut off some noise with the EVM is more valuable to me.
You dont have an exhaust button in your car?
I'm confused how you think the EVM will make your car quieter.
Old 05-28-2020, 07:16 PM
  #72
DriveAMG's Avatar
2019 E63s
The EVM
I'm confused how the EVM will make your car quieter to pass testing.
adds noise to my car without me having to cut the secondary cats. The module was not done for any track purposes only street to ADD noise without any hassles of removing anything.
At the track I don’t need the module really because at full throttle in Race Mode everything will be wide open already.
When you are noise tested at the track they are wise to exhaust valves and make sure that your system is set to open when they measure. Thus removing cats could possibly mean not being able to run because I’m too loud.
Sorry for the confusion.
kumizi (05-28-2020)
Old 05-28-2020, 07:19 PM
  #73
Skilly's Avatar
noise testing at the track is not done flying by at full throttle. It’s done at idle at a prescribed distance. .
tell that to the old lady that lives adjacent to Sears Point with her hand held DB meter.
x96535 (05-29-2020)
Old 05-28-2020, 07:47 PM
  #74
DriveAMG's Avatar
2019 E63s
Next time you see her
Tell her there’s an app for that...😂
Skilly (05-28-2020)
Old 05-29-2020, 09:52 PM
  #75
AAQUINO11's Avatar
amg gts
After a week of owning my GTS I had the secondary cats removed. $120 bucks. Wayyyyyy better, perfect "loudness" way more pops and crackles. If you are contemplating just do it. Cannot beat it for the price you will be very happy. PLUS in comfort mode the car is as quiet as stock, best of both worlds.
Orcbolg (05-30-2020)
Quick Reply: I’m debating deleting my Secondary Cats...
