Took The GT to Motorama
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Hi all. Last weekend we took the GTC to Motorama at the Atlanta Motor Speedway. I thought I would share some pictures of the event. We were able to do a parade lap each day on the big track. Interesting enough at slower speeds the moment the car gets up on the big banks it throws ABS, Active handling malfunctions till after you drive a bit on level ground. I suspect if I was going much faster there would be no codes or if I had turned off ABS, ect before I went on the big track. If you want to watch the big track lap video here it is
Also i took the car through the autocross. It handled as good as it did with the original Continental tires. Car has the Michelin Pilot Sport 4s on it now. I did a 58.5 where the professional drivers were getting low 50s. Mind you I only did three passes and I didnt even look at the tire pressures before I ran. Otherwise put the car makes it EASY to do autocross. If you wish to watch the video of one of my autocross passes here it is
Heres a few pics from the event.
California John (04-30-2019)
Hi all. Last weekend we took the GTC to Motorama at the Atlanta Motor Speedway. I thought I would share some pictures of the event. We were able to do a parade lap each day on the big track. Interesting enough at slower speeds the moment the car gets up on the big banks it throws ABS, Active handling malfunctions till after you drive a bit on level ground. I suspect if I was going much faster there would be no codes or if I had turned off ABS, ect before I went on the big track. If you want to watch the big track lap video here it is https://www.youtube.com/watch?v=6nx6wL4S3-w
Also i took the car through the autocross. It handled as good as it did with the original Continental tires. Car has the Michelin Pilot Sport 4s on it now. I did a 58.5 where the professional drivers were getting low 50s. Mind you I only did three passes and I didnt even look at the tire pressures before I ran. Otherwise put the car makes it EASY to do autocross. If you wish to watch the video of one of my autocross passes here it is https://www.youtube.com/watch?v=NhYcBJF_c1w
Hi John. All show attendees could take their cars out on the track and race as many times as they wish if they waited their turn. I did not ask what body it was under. I will say it was ALL turns with no straightaways. As a matter of fact my first pass I experienced for the first time ever undesirable turbo lag coming out of turns. I fixed it in the final two laps be simply coming in hotter and hitting the gas sooner coming out of the turn.
I guess the best way to say was it was for fun as far as I am concerned........
Katie
Katie
Oh sorry. All my trips through were on sport plus. Same for my previous auto cross last year. Might try race one of these days. From what I read race dramatically turns down the active handling. My experience on sport plus is I never notice active handling kicking in on sport plus. In contrast with the Corvettes I have driven you better have car in competitive driving mode or you will experience the computer stepping in at times when you don’t want it to.
Ps would love to know exactly why I get trouble codes on high bank turns of the big track at low speeds.
Bushman I dare say your recipe is definitely grounds for the personal setting. Never thought of trying shocks at soft setting.
Caveat: IF the soft shock setting harms handling in a slalom area of the course, then maybe one click on the shocks would work best; depends on the course, so best to try a couple of runs on both ‘soft’ and ‘Sport’.
California John (05-03-2019)
