SD Card AMG GTC Roadster
Hello ---- does anyone have experience inserting an SD Card into the slot in the center console of an AMG GTC Roadster ? I have tried a few of the SD Cards that I have but none will slide into the slot ? Maybe I am using the incorrect size Sd Card ? I was unable to find anything in the owners manual regarding the size and type of SD Card .... any help will be greatly appreciated. Thanks in advance....
I use the slot that a thumb drive will fit in next to the SD card slot all the time in my coupe. If the SD card appears to be fitting correctly you may want to (if you haven't already) check on you center dash screen to make sure you have that particular slot selected to play. Good luck!
mgardner23665 (06-25-2019)
California John (06-27-2019)
The following 2 users liked this post by thecutter64:
MalibuScott (06-28-2019),
ZephyrAMG (06-29-2019)
Yep! Went to the dealer today. Turns out the car was delivered to me with a Mercedes Manual on a SD card jammed into the SD card slot. Not sure how they got it out but they did. Thanks to all !!
