For the owners here that track their cars, I'm sure you will have experienced some braking issues due to insufficient cooling with the OEM design. I've manufactured some brake ducts for the front brakes as seen in the photos below. I decided to make these for myself and my own needs but I have a few extra sets. Please let me know if you'd be interested in a set.
Mods, please let me know if this is not allowed and I'll remove this post.
The bracket you see has a hole which is used to mount to where the sway bar end link mounts to on the lower a arm. The two holes are for a cable tie to secure the duct around the a arm.
All you do is bolt the bracket up to where the sway bar end link with the provided nut. A cable tie is used through the two holes to secure it to the lower a arm. Detailed instructions including diagrams on how to cut the dust shield will be shipped with the ducts.
