Amg gtr lowering on stock Coilovers
TIKT coil overs
Now that you’ve had the TIKT suspension for a while do you still like it? How is the street driving with the setup as well as the adjustable suspension pieces? I track and street drive my car frequently but not happy with the stock setup.
skilly.....i have the renntech's on my gts and haven't adjusted them yet but need to. are you able to turn them with the car up in the air and with the wheels on to take some of the weight off of the spring, or do you have to remove the wheels to gain access to the collar and get the wrench in there. i haven't tried yet, but would rather know the best and easiest way before i try it. thanks!
A question to you all technical guys. See attached pictured of the coilovers front and rear on my Pro. To lower the car, should I open lock screw an lower the upper ring? I don't want much lowering, just down to the stop ring lowest. If this is correct I will do the lowering myself. Thanks for all advices here.
Front
Rear
Front
Rear
That is the standard procedure of lowing yes, just loosen the lock ring then use turn the spring perch.
However, I think the pro's front doesn't really have any room to go, the rear does but not sure if you want to change the wake of the car - that affects the handling characteristics a lot.
#32
I haven’t driven the car to much because of snow an bad weather. I will have first trackday in May so I know more the. Ride height is down about 1.2 cm all around.
#33
Look forward to hearing more ... hope you have a great track day.
#34
E55, Z06
Thanks!
#35
I went for a drive on road this weekend. So far my butt feeling says that ride height and comfort is very acceptable. Actually, I would say comfort is even better than on a standard GTR and GT, which also several magazines has reported. I am very impressed how the suspension tackle bumps and bad tarmac. Looking forward to test on track.
#36
I did get a mechanic to help me, but yes jack up one corner at time. I checked all gaps on on all corners at it was similar so I lowered until reaching stop ring. I will check height on all corners after my first trackday.
#41
Hi,
The GTR has a height-adjustable coil springs. But, their maximum depth is limited by a stop.
This stop is an aluminum threaded ring, secured with a pressed-in steel pin. (therefore not twistable)
The steel pin can be removed, but it will be easier to remove the entire stop aluminum ring. (Has no other function)
There is enough thread on the shock absorber to go to max depth.
I can't say up to what depth it still works well. Haven't tried it myself. The max possible depth to the stop was enough for me.
You can try it, because you can go higher at any time. The costs are near zero.
Best regards
Stenzel
Best regards
Stenzel
jb123mb (10-03-2022)
#42
How much harsher does it make the ride?
#43
Hi,
Does not change.
You don't change the spring rate or the damping rate.
A high damping rate is usually the cause of "harsh" suspension.
The spring is rarely the cause.
But it may be, that you get into the compression stop, if you set it too low.
The ideal damper working range could also be left.
You just have to test it. The effort is initially low.
If it doesn't fit, you go back. Doesn't cost anything up to here.
Mostly (experience with other cars) 1-1.5" with shorten or aftermarkt springs, work quite well, with stock length shock absorbers.
I have no further experience with GTR series shock absorbers because the maximum series depth is completely sufficient for me.
Best regards
Stenzel
Does not change.
Best regards
Stenzel
jb123mb (10-04-2022)
#44
Hi,
Does not change.
Best regards
Stenzel
Does not change.
Best regards
Stenzel
