AutoTalent | Renntech Performance Ecu+turbo+brake for Mercedes-benz Amg GTC 2018-2019
Old Oct 22, 2019 | 05:08 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. Our proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s. RennTech experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RennTech performance software unleashes the true potential of your Mercedes. With the proprietary RennTech ECU Tuning the C190 AMG GT C gains up to +84 HP and +93 LB-FT, based on power numbers measured by RENNtech. Please note that the Mercedes M178 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RENNtech ECU Upgrade fot the AMG GT C is 659 HP and 614 LB-FT.
Features
Gains: +84HP & +93LB-FT
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance
550 HP @ 6,250rpm; 502 LB-FT @ 1,750-4,750rpm
575 HP @ 6,250rpm; 521 LB-FT @ 3,850-5,400rpm
Modified Performance
659 HP @ 6,150rpm; 614 LB-FT @ 4,450rpm
580 whp @ 6,150rpm; 540 wtq @ 4,450rpm
Renntech Performance Turbo Upgrade
Click HERE to order Performance Turbo Upgrade!
The Mercedes GT C is the second Mercedes Benz vehicle fully developed by AMG, the company’s Affalterbach based performance division and long fabled engine builder. The resulting vehicle is nothing short of spectacular and the 4.0L V8 BiTurbo engine within is an incredible platform to build performance upon. RennTech lightweight forged billet turbo wheels feature a dramatically larger than stock impeller (inlet side) and an increase in the turbine trim (exhaust side). This combination of high quality, light weight components compensates for turbo lag despite being a functionally larger turbo. The cartridge supporting shaft is also both larger and stronger designed to handle the larger wheels and additional power. This entire cartridge is then fine balanced as a complete assembly to compensate for these increases. The impeller and turbine housings are then precision CNC machined and flow tested in-house to fit the larger internal cartridge. The end result is nothing short of spectacular with the RennTech turbo package gaining up to +186 hp and +111 lb-ft. More power isn’t the only performance benefit as our turbos spool quicker, offer a more responsive throttle and immediate power delivery thanks to a reduction in exhaust back pressure, rolling resistance, higher RPM's and a lighter rotating mass. In addition, our turbo upgrade kit functions with the OEM oil and coolant lines. This isn’t just an OEM turbo charger with machined internals; but a dramatically larger, more powerful turbocharger that blows away anything else on the market. The RennTech performance turbo upgrade is truly the ultimate upgrade for your AMG GT C.
Features
The RennTech Stage I Turbo Upgrade comes with an RennTech ECU Upgrade and Fuel System Upgrade.
Larger impeller (inlet) and turbine (exhaust) cartridge
Cartridge shaft is larger and stronger to support larger wheels
Entire cartridge is fine balanced as an assembly
Lightweight forged billet wheels
Less rolling resistance offers quicker spooling
Virtually no lag with impressive throttle response
Precision machined impeller and turbine housings
Up to 761 HP and 632 TQ
Gains: Up to +186HP | +111LB-FT
Stock Performance
515 HP @ 6,250rpm; 494 LB-FT @ 1,750-4,750rpm
536 HP @ 6,250rpm; 495 LB-FT @ 3,850-5,400rpm
761 HP @ 6,800rpm; 632 LB-FT @ 5,600rpm
670 whp @ 6,800rpm; 556 wtq @ 5,600rpm
Renntech Exhaust Valve Module
Click HERE to order Exhaust Valve Module!
RennTech plug & play EVM Exhaust Valve Module allows you to open the exhaust flaps of your car 100% at all times by pressing Button 1 on the remote control. If you wish to go back to factory settings simnply press Button 2. This gives you complete control over the exhaust sound and rumble of your car at any time regardless of speed, RPM or driving mode. The RennTech Exhaust Valve Module is made in Germany. If your car is equipped with factory exhaust flaps, with or without a center console button to open or close them, factory settings do not allow the flaps to fully open unless certain speed and/or RPM have been reached. For example, while cruising the exhaust flaps will never fully open.
Features
Activation completely independent regardless of drive mode
Override your cars factory exhaust flap setting with the push of a button.
EVM does not engage with CAN-Bus
No interference with any control units.
Software updates do not interfere with the functionality of the EVM exhaust valve module.
Plug and Play with original plugs
No cutting wires, no damage to factory cables, fully reversible.
1 x Exhaust Valve Module
2 x Remote Controls (Button 1 fully open, Button 2 back to factory)
Wiring harness (model specific)
Installation manual
Renntech Performance Brake Upgrade
Click HERE to order Performance Brake Upgrade!
The custom RennTech steel front brake package is a must for every AMG GT R track setup. Our custom developed rotors increase braking efficiency and 'bite' as well increased longevity. Instead of being drilled, our brake rotors are slotted which makes them less prone to cracking when compared to the OEM Rotors. Due to the fact that the RennTech rotors are different between the left and the right rotor, we were able to improve the cooling of the rotor for superior thermal capacity. The RennTech High-Performance Brake Rotors come in a complete kit of 2 rotors (left and right), already assembled with the heats ready to be installed.
Features
Heat treated for micro structure alignment and durability
Runout less than .0005 inches and thickness variation less than .0002 inches, reducing pulsation and vibration
Temperature range from 122deg – 1300deg (wide operating range)
Vanes turned OD and ID for balance to reduce thermal warping and vibration
48 vanes for superior thermal capacity
Surface finish less than .7 microns.
Renntech Coil-Over Suspension
Click HERE to order Coil Over Suspension!
RennTech GT-C adjustable suspension kit offers not only overall improved aesthetics and an aggressive vehicle stance, but improves both vehicle handling and performance. RennTech proprietary suspension kit lowers your vehicle up to 1.5" via adjustable spring perches on your OEM dampers. Constructed of high strength, light weight aluminum our suspension kit allows four-corner independent ride height adjustments and the ability to perform vehicle corner weighting. RennTech complete suspension conversion allows full adjustment without the need to purchase an entire coilover conversion kit and comes with an adjustment tool to make on-the-fly suspension adjustments.
Features
RennTech sport lowering springs for front and rear
RennTech height adjustable spring perches for front and rear
RennTech adjustment wrench for spring perches
Lowering Range: 1.5" front and rear
Four corner height adjustability
OEM electronic damper control is retained
Aggressive, lowered vehicle stance
Improved vehicle handling and performance
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
