GTR vibration issues
Old Aug 5, 2020 | 06:15 AM
JohnyPhillipsAMG.GTR's Avatar
C180
Old Aug 5, 2020 | 07:21 AM
DriveAMG's Avatar
2019 E63s
Seems simple
Try removing them and see if the problem persists. Other potential causes could be your tires. Have them checked to see either if they are out of balance. If they are ask for a road force balance.
Old Aug 5, 2020 | 11:09 AM
NYCSoiL's Avatar
2018 GT R; G82; M340
Try to balance your tires, could also be a bent rim
Old Aug 5, 2020 | 03:33 PM
Tinknocker's Avatar
2016 gts
Yup , have all four rims/ tires balanced. The little aero should not have any noticeable difference.
also look at the wear on the tires , might be time for some new sport cup two tires.
Old Aug 6, 2020 | 01:02 AM
triblk6spd's Avatar
18 AMG GTR . 18 Tacoma . 02 BMW M3 (the sickness)
I mean the easiest answer to, "is it the cannards" is... was this an issue before they were installed and did this become an issue right after?
If they have always been on the car since you took possession and the vibration has been there since then I suggest you remove the canards and see what happens. That said I'd think there would be only a very small chance they could cause THAT kind of vibration.
Old Aug 6, 2020 | 02:10 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
If your wheels are balanced, I’m guessing it is a wheel alignment problem.
