Transmission Service
Slightly off-topic, but relevant to service pricing:
I noticed that dealerships who use the RevolutionParts.com platform on their Parts Dept website — where you can order parts online with a discount — also tend to have lower service costs compared to those that require you to request parts via a web form or phone. (Not in all cases, but one method to test prices. Check it out)
I completely agree. If a dealer doesn’t have an AMG-certified technician, it’s not worth the risk—especially when it comes to servicing the Getrag DCT transaxle.
2018 AMG GTS - Porsche Panamera Turbo - Supercharged BMW E60 M5
Really dumb question but I had to disconnect the transmission lines that shift the transmission drive selection. I'm trying to figure out which fluid needs to be replaced as mentioned there are two types. Any help is very much appreciated.
The transaxle has two compartments – A Differential side that holds the MB 236.26 GL5 gear oil, and a Dual Clutch Transmission side that holds the MB 236.25 DCT-F3 trans fluid especially formulated for the clutches.
Both of these fluids are produced by Shell Oil company and the only brands MB approves for use in the 7DCL750 transaxle.
Other off-brand products might, or might not work, but the gamble becomes yours. For off brand, make sure they state the MB 236.26 and 236.25 respectively.
Here is a video for transaxle fluid change for the older AMG SLS, but once you get to the actual transaxle part, it is the same as for the AMG GT:
I also attached the MB WIS fluid change procedure pdf
These are the items you will need for the fluid change:
You may also want to visit post #10 and #17 above for more info
I forgot to mention:
The fill quantities are: Differential side: 3.7 liters / 3.9 qt of gear set GL.5 MB 236.26 Shell Spirax S5 ATE 75w-90 oil, and Transmission side: 7.8 litters / 8.25 qt of the hydraulic ATF MB 236.25 Shell TF DTC-F3 oil.
So I added the new 236.25 transmission fluid and I'm not able to get the transmission past 1st gear. Putting it in reverse and drive are quite clunky. I tried the transmission adaptation procedure but it failed saying it could be the fluid level. I added 8.25 quarts. Any ideas on what I'm doing wrong?
Was the car in N gear when you run the process?
How much fluid did you remove during the drain? Did you add that amount plus 1L?
did you emptied and refill the correct side? Trans vs. Diff?
other than the above, I am not sure what is going on
could your current issue have to do with the above?
I added 8.25 quarts of fluid to the trans since that was the fluid that escaped while pulling the transmission. The car was off and in park while I put the trans fluid in. I guess I may have missed a step as I didn't let the excess out of the fill port after filling it, seems like an odd step.
So I re performed the process and had the car in neutral as I refilled it and I'm getting the same results. It clunks into gear and will go into drive (1st gear only), reverse, neutral and park. Any idea on what might be the issue?
No, I had to disconnect the lines to drop the transmission because I replaced the rear main seal. I had to replace the trans fluid due to fluid escaping while removing the lines.
2016 AMG GTS, 2018 Volvo V90, 1956 Ford F500, BMW R1150R
Hey folks - yes I've connected with c34webb. This is a frustrating experience I'm sure. I'm sure any of us would have uncomfortable concern with any odd noises coming from our cars - and unfortunately many noises have been reportee. Any "thud" out of park to neutral or into gear would make me wonder if the park lock is gooed up by common grime and grit getting into the actuator through the park lock bolt which is secured from the outside of the transmission casing. But the fact he can get into gear is weird. Any thud heard may be the synchronizer ring not being lubricated enough to slide over the first gear after the SAP sends the signal from the SAP (shift actuator plate).
When changing gear fluid it's so crucial to run the car a few hundred feet, put it back on the lift, open the filler screw and top off the fluid until it drains out of the filler hole. To do so, one must use an m18x1.5 filler adapter which allows fluid to flow out of the device, but any resistance or fluid moving against the adapter (overflow) will start to dribble out. This is an inexpensive, and very well made unit: I'd definitely start with verifying fluid is in the transmission properly. 7 liters of DCT fluid and 3 liters of gear oil is spec.
By the way a reminder, I have a new manual updated with a few odds and ends. You can find version 1.3 on my shared drive. It gives all the specs and how-to for the fluid chanegs at the bottom of the manual. Getrag 7DCL750 Ferrari AMG GT Ford GT Repair Docs
When changing gear fluid it's so crucial to run the car a few hundred feet, put it back on the lift, open the filler screw and top off the fluid until it drains out of the filler hole. To do so, one must use an m18x1.5 filler adapter which allows fluid to flow out of the device, but any resistance or fluid moving against the adapter (overflow) will start to dribble out. This is an inexpensive, and very well made unit: Oil Extractor Pump and Filler Kit I'd definitely start with verifying fluid is in the transmission properly. 7 liters of DCT fluid and 3 liters of gear oil is spec.
