A couple of issues with my car
Old Aug 17, 2020 | 08:35 PM
RSKDSK's Avatar
2018 AMT GT Roadster
All,
My first post here ... I have a 2018 GT Roadster with 16k miles on it now. I just set up another appointment with my dealer as I have the start button not working issue, moisture/condensate coming out of the AC vents, and the top malfunction (sometimes).
I'll do a search to see if these are common issues ...
Old Aug 17, 2020 | 08:48 PM
SLcruzen's Avatar
300sl roadster
moisture and condensation should not come out of A/C vents... removal of condensation and moisture (humidity) is the primary function of an A/C unit.. if you live in an area with super high humidity values and high temps and leave your windows open, then you should have moisture on the vent parts,.. other than that, I've had two roadsters and the start button functions correctly every time... maybe something was spilled on the console and seeped around the button to cause an issue....
Old Aug 18, 2020 | 06:13 PM
Sam1723's Avatar
AMG GT
What exactly is the issue with the start button? Is it stiff or can you press it?
Old Aug 18, 2020 | 06:46 PM
RSKDSK's Avatar
It does not press ... however I was able to place two feet on the brake and push really hard ... then start using the button ... it seems relatively common for these cars
Old Aug 18, 2020 | 06:49 PM
Sam1723's Avatar
AMG GT
Some days when i go to first start my car the brake is super stiff. It wont allow me to press it down at all, but i can still press the start button which only lets me turn on the electronics. I have to manually put the key in the arm rest and turn on the engine. Not sure if this is similar to what you are experiencing.
