Fuse Slots for Dash Cam Hardwiring
Old Sep 1, 2020 | 02:22 PM
big_willy's Avatar
Hello Guys,
Can someone point out which fuses they tapped into for hardwiring of a dashcam. A diagram would be great. Thank you.
Old Sep 3, 2020 | 01:36 AM
x96535's Avatar
2016 AMG GTS
Originally Posted by big_willy
Hello Guys,
That’s my bad. I completely forgot to get a pic. I’ll set a calendar reminder to knock it out tomorrow and post on here.
Old Sep 3, 2020 | 08:04 AM
DriveAMG's Avatar
2019 E63s
Get the battery too
It’s the best solution. That way the vehicle electronics aren’t bothered. You turn off the car it switches to the external battery. Turn on the car it discharges the battery and keeps the camera on. Best solution. I’ve been using this setup now for 3 years no problems
Old Sep 3, 2020 | 04:55 PM
x96535's Avatar
2016 AMG GTS
This is the fuse box under the passenger side kick panel.
If you’re running the Magic Box or an equivalent, you’ll need to tap in two places. One is for constant on and one is for power only when the vehicle has power.
The top one is constant on. It’s the seventh fuse from the top on the left or the first one above the green relay. (Sorry the pic turned when loading. Top is to the left of the pic)
The second one is only powered on when the car is on. It is the third fuse from the bottom left. (Bottom is in the right side of this pic since it flipped on upload too)
Old Sep 3, 2020 | 11:00 PM
big_willy's Avatar
Thank you for this. Most appreciated 🤘👍
