Battery problem
Old May 11, 2021 | 08:23 AM
paulneal's Avatar
amg gts
Battery problem
Hi All,
I am based in the UK and i am looking for some help with my battery.
My GTS has developed a fault that displays on the screen as "Charge Battery" in white followed by "Charge battery" in red.
Neither of these can be cleared to get back to the normal display.
The battery is fine and the car starts ok etc. etc. The battery at rest reads 13.75 volts and all is well.
Any help would be appreciated.
Paul.
Old May 11, 2021 | 11:12 PM
LAsunset's Avatar
Fast and Really Fast Sports Cars
At rest seems high. Do you mean 12.75V?
Old May 12, 2021 | 11:55 AM
Stenzel-Germany's Avatar
AMG GTR
Hi,
Start Engine. Measure the voltage.
Stop Engine. Wait 15 min. Measure the voltage.
Respond here.
Kind Regards
Stenzel
Old May 13, 2021 | 10:03 AM
paulneal's Avatar
amg gts
Test
Hi guys i ran the test and the battery reads 13.4 volts. Car starts fine etc etc. Dashboard in red saying charge battery.
Old May 13, 2021 | 10:14 AM
4wheelz's Avatar
None yet
Do you have the battery charger/conditioner that came with the car? If so have you connected it to the rear 12v outlet in the back of the car to let it recharge the battery?
https://mbparts.mbusa.com/oem-parts/...E&gclsrc=aw.ds
Old May 13, 2021 | 10:16 AM
paulneal's Avatar
amg gts
I looked for the rear charger but could not find it. I have driven the car on a 1.5hr run and it still says the same all the way.
Old May 13, 2021 | 10:53 AM
4wheelz's Avatar
None yet
When you open the trunk, look in the left back corner and there is a round 12v charging port there to connect the MB charger to.
you connect the charge port with the vehicle off and let it sit overnight. The MB charger has some indicator lights that will tell you how low or full the battery is.
Old May 13, 2021 | 11:11 AM
paulneal's Avatar
amg gts
Thanks for that I will have a look later. However, it still does not help me as i cannot get past the alarm on dash to even see the odometer etc.
Old May 13, 2021 | 11:14 AM
4wheelz's Avatar
None yet
No problem - not 100% sure, but the warning is pretty critical as if the battery dies, it cannot be jumped like a regular battery and you’re just stuck. My guess would be if you can connect it to the conditioner/charger overnight (or possibly longer), that when it shows it’s fully charged, the DIC alert/message would go away.
Old May 14, 2021 | 03:00 PM
BurtReynolds's Avatar
AMG GT Black Series
Back to basics, have you tried just unplugging the battery from vehicle to reset the system? I know it's old school, but sometimes the simplest/easiest solution works, like hitting your starter with a hammer haha.
Old May 15, 2021 | 03:28 AM
paulneal's Avatar
amg gts
Yes i have done the disconnecting for 5 mins. No good.
