Check Engine Light
Thanks in advance!
On misfires, these can be caused by either (or both) ignition issues or fueling issues. Ignition issues can be spark plugs, coils, associated primary or secondary wiring feeding the ignition source. On the fueling side, primarily fuel injectors can contribute to misfires either by becoming clogged or dirty causing an intermittent fueling void, or by leaking injectors that start to dump fuel when it isn't required. Also, an intermittent electrical input to these injectors could cause the problem.
The algorithm the EMS uses to measure and determine a misfire has a counter and a timer. There has to be a "number" of misfires and within a prescribed time to set a CEL. So, if you're getting the CEL returning consistently these two cylinders are showing some consistent issues. The only other possibility is an ECU that has gone defective (not likely). EDIT: And I should have listed that the CPS delay could be set too sensitively.
With the limited info given, and since you say that the engine runs smoothly and has full HP, I'd have to take an internet guess and start with fueling. Weak coils and or bad spark plugs would likely get worse under harder performance, but a leaking injector wouldn't necessarily.
I just went true the same experience (even changed a coil pack before doing this) and still got a misfiring message. After this simple treatment all misfiring went away ones Techron cleared my injectors.
Best H
Techron is sold in parts stores and Walmarts in two strengths. There is a gray bottle called Fuel Injector Cleaner, there is a better version, the black bottle called Fuel System Cleaner.
They're both Techron, but the Fuel System Cleaner in the black bottle is a higher concentration of Techron. I've been using Techron regularly for 3 decades now. It's a good product for ongoing fuel system maintenance, and can be had on a regular basis just by purchasing gas at Chevron stations. But, buying a bottle and adding it to the tank (a full tank), occasionally, gives a little extra. By occasionally, I mean once or twice a year.
One caution though, I strongly recommend following the dilution instructions on the bottle. You don't want to keep a high strength dose of Techron in the fuel tank and the system for long periods.
Look for this product (Concentrate Plus):
They told me if it comes back they can change all spark plugs under that known issue even if the car is not in warranty.
The check engine light mysteriously went off for a little while, then it came back on. Taking the advice of others in this thread, I ran the tank down to one bar on the gauge, poured in a bottle of Techron, added 12 gallons of fuel, applied liberal amounts of right foot pressure and voila... the check engine light turned off after 40-50 miles and has not returned since.
Thanks to everyone on the GT forum for the continuing education! Forums are SO MUCH better than social media.
If you're just adding it for ongoing use, the dosage recommended on the bottle is best. It's about 12 oz for about 18 gallons of gas. The 20 oz bottle would work for a much larger tank. I only add a 10 oz bottle of the concentrate to my cars about once a year because I get Techron in my gasoline at the pump all the time so I am using it always.
Techron is fairly safe, but you shouldn't go crazy with high concentrations for long periods left in the tank. It can be a little aggressive and really unnecessary in prolonged high concentrations.
Hope that helps.
Hope that helps.
Grant
I've seen it in other manufacturers. These are not real misfires. It's that "thresholds" on the delays the ECU sees through the Crankshaft Position sensor is set too sensitively. So, they create a simple SW patch to modify the data table the ECU is using to measure the delays. A lot has to do with the ways a particular engine is wearing in over time. Maybe the misfires start to appear in one car out of a high number of cars, enough that the factory creates the patch. It won't be a general recall, just cars coming in with misfires showing up, but they are not real misfires. They apply the DT change which modifies the threshold and the misfires magically stop appearing BC the ECU is no longer responding to the same sensitivity in crankshaft delays.
Grant
Th other thing that I see sometimes, and here it's important to say, I am not trying to impugn ANY tuner anywhere, is that some tuners will simply desensitize certain ECU functions so their tunes (toons) are not constantly setting CELS or responding to ECU corrections. Lots of ways tuning is shortcutted BC it's easier to change a threshold or sensor sensitivity so the ECU doesn't respond. I've seen it on knock sensor timers and delays to stretch out the high octane timing tables rather than putting the time in to get the timing table correct. NOT good.
It's that delay I was describing. The ECU can respond to delays you wouldn't necessarily feel, seat of your pants.
And, the shake you're feeling might not be related to a misfire. Could be where the tuner set the VVT, if they modified it.
I believe that any the amount of time, research and money that the factory puts in is very hard to match for any after market tuners.
Enjoy your car.
Best H
