Wheel help
They have offered to make a set of 3 piece for the same price but I'm concerned about the "trough" in the barrel of 3 piece wheels.
Is that still an issue with 3 piece wheels? I had a set of 3 piece HREs on an E55 that was ridiculous to drive if it rained.
Can anyone confirm the "trough" issue? Share pics of your multi piece wheels with CCB fitted? Recommendations?
TIA -
So that other's know, 3-piece wheels that have a "reverse lip" design (a lip without a "step") water can get temporarily trapped within the barrel near the mounting flange of the center face. This could occur whenever water is near the wheels (raining, car wash, etc.). If it happened, the water would make the wheel balance uneven and cause vibrations making it feel as if the wheel was out of round or you had a flat tire. Over the years wheel manufacturers have moved away from these types of lips and use step lips instead which eliminates virtually all of these problems.
Frontdisks:
Carbone: 402mm x 39mm
Steel: 390mm x 36mm
Steel: 360mm x 36mm (Only GT - 2019)
Reardisk:
Carbone: 360mm x 32mm
Steel: 360mm x 26mm
With carbone brakes you need a bit more diameter over the brake calibers and clearance to the rim spokes.
I do not understand why 3-piece rims should then go?Here the free place is rather smaller.
Kind regards
Stenzel
