Frustrated with Water Leaks / Driver side footwell
2018 AMG GT-C Roadster; 2018 Range Rover Velar;
I have had warranty repairs on my GTC roadster (UK) to address water ingress - first the seals around the A-pillar that was causing water to collect in the passenger footwell; then seals on the rear bulkhead causing water to leak into the boot.
This past week I am seeing water collect behind the driver side seat and in the footwell! The boot is dry.
The drains have been kept clear and cleaned periodically ( I learn that lesson sharpish!) so really frustrating
I am within a year of the previous warranty repairs so have a good idea to give the dealer a ring before the ECU modules go on the fritz again.
Anything I can do?
Anything I can do?
Anything I can do?
Anything I can do?
I would take the car back to the dealer wirh the leaks/water in place. That way they will have a chance to locate the source(s).
Also and hopefully other owners may have registered similiar leaks issues to aid in identifying a solution.
Good Luck.
Jerry
