AMG GTR Pro front sway bar adjustment
Pro owners, have any of you able to adjust the sway bar stiffness of the front sway bars from soft to hard setting? I was able to adjust the rear fairly easy but stuck with the fronts, no matter how I adjust the preload of the suspension to align the end link bolts, there simply isn't enough space to let the endlink bolt slide through the first hole of the swaybar.. the shock is in the way.
Would be good to hear some experience if any of you have made the adjustment. I'm trying to get both front/rear to stiff setting to reduce a bit on body roll.
Have done quite a bit of playing with the shock settings (and posted some info), but not the sway bars. I hope you will report your findings, once you complete the adjustments. In particular, the track handling and street-ride changes. Oh, and it'd also be nice to see some pics of the completed adjustments (I don't ask for much, do I). #;-)
