firing order
Old May 14, 2022 | 02:13 PM
Stenzel-Germany's Avatar
AMG GTR
firing order
Hi,
as I am abroad and do not have access to WIS, can anyone reliably tell me the firing order of the M177 and M178.(should be the same)
Google is contradictory
Best regards
Stenzel
Old May 14, 2022 | 03:50 PM
57 GTR's Avatar
2018 Diamond White GT-R
Another side effect of the move to a flat-plane crankshaft is a new firing order. The 4.0-litre V8 now jumps between cylinder banks, with a 1-8-2-7-4-5-3-6 firing order. This creates uniformly oscillating gas columns which generate a predictable flow of gases through to the turbochargers.
Old May 14, 2022 | 05:10 PM
AMG GTR
Originally Posted by 57 GTR
Another side effect of the move to a flat-plane crankshaft is a new firing order. The 4.0-litre V8 now jumps between cylinder banks, with a 1-8-2-7-4-5-3-6 firing order. This creates uniformly oscillating gas columns which generate a predictable flow of gases through to the turbo chargers.
Hi 57 GTR,
thanks, but this is for M178 LS2 with flatplane crank. (e.g. Black Series)
Need the firing order for M178 LS 1 with cross plane crank.
Best regards
Stenzel
Old May 14, 2022 | 05:20 PM
57 GTR's Avatar
This firing order is 1-8-4-3-6- 5-7-2. Just as with the LS1 example above,
Old May 16, 2022 | 02:14 PM
AMG GTR
Hi 57 GTR,
Thanks, but are you sure? Where did you get the information from?
1-8-4-3- !!!6-5-7!!!-2
Here, 3 cylinders would fire one after the other on the left (direction of travel) cylinder bank.
Is this firing order, with this cylinder counting?
Transmission
4 O O 8
3 O O 7
2 O O 6
1 O O 5
Front of car
Best regards
Stenzel
