Small "Button improvement" interior. For Free.
Hi,
Because Mike is in the process of removing his center console.
If you remove the center console anyway. Can you swap buttons at the same time.
Have that from the start. Find it more practical. The rear buttons are the "worst" to use.
Ignition on, start/stop off, D engaged. Start/Stop is no longer needed.
Exhaust flap button is certainly used more often as the start/stop button.
Works the same with ESP/shock absorbers. (Find ESP in front, better)
Fits mechanically and electrically without any problems. Extra 5 min, bolt on.
(For the analogue models) As far as I know, digital has 2 continuous units.
Kind regards.
Stenzel
In pic is the stock version.
Kind regards.
Stenzel
lgarcia (10-03-2022)
