Can we figure Code P0299 Turbo 2 ?
Subscribe
Oct 19, 2022 | 05:13 PM
Tech said light on and that it’s showing low boost pressure and recommends replacing turbo and Lines. Any ideas? If Turbo does need to be replaced where would be the most inexpensive way to obtain the turbo? Does anybody do remanufactured? Thanks in advance.
Reply 0
Oct 19, 2022 | 05:35 PM
Quote: Tech said light on and that it’s showing low boost pressure and recommends replacing turbo and Lines. Any ideas? If Turbo does need to be replaced where would be the most inexpensive way to obtain the turbo? Does anybody do remanufactured? Thanks in advance.
Sorry about your problem.
Check with RENNtech and Weistec. If they don’t have their own to market they should have takeoffs they will sell.
Best regards
Jerry
Reply 0
Oct 20, 2022 | 04:54 AM
Turbos
Let me know the part #'s you are looking for. I'll check if I have extra set or get you the name of a good re-builder
Reply 0
Oct 20, 2022 | 08:04 AM
Thank you I believe I found the part. What independent does everyone use to work on benz in Atlanta? Any ideas?
Reply 0
Oct 20, 2022 | 12:09 PM
I don't know an independent in Atlanta, for turbo rebuilds I have used turbodallas.com with good results for my V12 rebuilds.
Reply 0
Subscribe
Currently Active Users (1)
