Sport Cup 2’s
The other thing to be aware of, the Cup 2 as do most track tires start out at a lower initial thread depth to reduce flex. Performance tires don't develop their full potential until they are worn down to about 6-7/32", so the Cup 2 starts out at 7.2/32" so that you don't have to wear them down first for maximum grip and performance.
Last point, AMG does not put ZP tires on their V8 models. The MO1 Cup 2 is not a ZP tire.
The OEM SC2 ZP tyre could be ordered in the rest of the World; (ROW), but not the USA. It is however the exact same tyre as came standard on the C7 Z06 with the FE7 (Z07) option, and is a much faster tyre on a road course, (by at least 2-3 seconds/lap on most courses I’d guess). It is a far more compromised street tyre though as it needs even higher ambient temps to perform at it’s best, and in fact it would be difficult to get them up to the optimum operating temperature on the street and not go to jail for it. Also, in wet, cold conditions you will be sliding all over the place. They have far less ‘tread’ than the SC2 and will wear faster as the compound is different also. They can be used in the summer on the street should you want to though.
The ZPs themselves only are super stiff on one side; (the inner aspect iirc) to provide the ‘Runflat’ advantage, although it basically allows you to pull off the highway safely and drive no more than 50 (?) miles before they are ruined. That means that even though they have less compliance than the OEM SC2, they are still relatively easy to live with on the street; again in warmer, dry weather.
