Fixing P1CE8 and P1CE7 DTC
Former Vendor of MBWorld
I keep seeing cars we tune come in with these codes and often times it is because of an aftermarket intake or errors in the tune. If your tune doesn't account for the intake, you can get these codes, so I figured I'd make a thread about it. It is not always a vacuum leak, and rather than spend thousands trying to chase a problem, we can resolve the errors with an ECU flash.
I make a fix for this on all modern bosch MED17 equipped benzes, if you need help you can always contact me. I know how annoying it can be to have a check engine light and not know if it's a serious issue or not, so if this code or any code pops up that you need help diagnosing, I'm here for you.
